TunerPro RT software questions
Old Dec 13, 2005 | 02:37 PM
DrEvo's Avatar
Originally Posted by TTP Engineering
Your conversion is off. 14.5psi is listed x2.
Damn good catch, this was a screenshot of my first attempt. The correct one is attached now. Thanks.
Old Dec 15, 2005 | 09:49 PM
DrEvo's Avatar
We drive JDM derived Evo's but this is the USA, lets default that to Psi so everyone can understand it. This goes for the low/mid/hi set points too if possible. Thanks Bob.
Bob, let us know when we can try this out, when you get it done of course.....
Old Dec 16, 2005 | 10:17 PM
TTP Engineering's Avatar
We are currently working on a TTP reflash combo to be used with the MAFTPro. We will be bringing open loop fuel control available much earlier in the load and rpm range. We will be testing this out in the next week. It is my premonition that the MAFTPro will become a near standalone once we open up the ECU to take the MAFTPro's commands earlier, which will soon be TIMING CONTROL.
IN THE MEANTIME, WE CAN START WITH THE:
2003-2005 EVOLUTION LAUNCH LIMITER NOW AVAILABLE! Woohoo!
www.ttp-engineering.com/store Check it out!
Select your standing still launch control stutterbox at 4500-7250rpms and build 10psi boost off the line!
Old Feb 18, 2006 | 08:35 PM
dryad001's Avatar
Sorry to bring this back from the dead. But I have been wondering about this table the last few days.
Now the table goes to 40+psi. Most of us won't hit that mark, at least I know I won't. Now is there a way to use more of the cells than right now? Say drop the peak boost to around 30-35psi? That way the table will be able to be more finely tuned especially in the lower boost, might even help with tip-in.
Old Feb 18, 2006 | 09:34 PM
PVD04's Avatar
That chart is showing absolute pressure, not gauge pressure. The peak boost available on that chart is actually around 30 psi.
-Paul
Bob_tm
Jan 5, 2018 04:45 AM
2fast2evo
Oct 19, 2014 02:35 PM
dryad001
10
Jul 5, 2008 07:13 AM
dryad001
16
Dec 1, 2005 07:15 PM
