Second O2 Sensor with PFC D-Jetro
Old Mar 6, 2006 | 09:14 PM
denial's Avatar
Is this even used? I know the PFC uses the first O2 sensor located in the O2 housing, but what about the second? Can I just unplug it altogether?
Reason why I'm asking is I'm thinking of putting my wide band O2 sensor in there in place of the stock O2 sensor. I'm catless so that shouldn't be an issue. If anything it makes for easier wiring into the cabin.
Thoughts?
Old Mar 7, 2006 | 05:55 PM
Guru's Avatar
Not used. You can unplug it and use the port for a wideband if you have no cat.
Old Mar 8, 2006 | 07:32 AM
denial's Avatar
thanks
Old Apr 3, 2006 | 05:04 PM
paulr33's Avatar
assuming the second 02 sensor is used by the stock ecu?
Does it do an average between the two or something?
Old Apr 9, 2006 | 09:13 PM
Guru's Avatar
No, the second O2 does nothing except tell the stock ECU if the cat is functioning or not.
Old Apr 11, 2006 | 10:55 PM
Spoolin Spyder's Avatar
does the evo pfc have the function to turn on and off o2 feedback ?
Old Apr 12, 2006 | 02:17 AM
paulr33's Avatar
yep under ETC, FUNCTION SELECT according to manual
evobanjo
Sep 15, 2010 12:55 PM
johnnyli
14
Jun 29, 2009 12:52 PM
EricR
Apr 25, 2006 02:43 PM
giangi
Apr 2, 2005 09:08 AM
SOARA
Oct 7, 2004 06:53 AM
