Need help with ECU pinout
I am trying a new perfect power SMT7 piggy back, and having some ECU pinout problems. I have the pinout from RRE website, and it isnt correct as far as I know. The Shop trying to install it has a few questions about the Evo pinout. This is on a 2005 Evo MR. Does anyone have the voltages for the ECU? Wiring diagram of the air flow meter? Dealer pinout of a 05 MR? How many teeth on the crank sensor? Ingnition pattern on the crank 60-2? And is there any difference from the Evo 8 to the MR on the ECU pinout. We are wondering if my car has an Evo 9 ECU. If maybe mid year change is possible. Thanks for all of your input.
I did a search, so don't complain about "thread from the dead".
There are at least a few differences between the 03 and 05 ECU pintouts. For example the 03 ECU has inputs for the intercooler spray switch (pin 44 and pin 57) to the ECU and output from the ECU to the dash light (pin 35) indicating that the intercooler sprayer is spraying.
So, since we have established that they are NOT identical, does anyone have the pinout diagram for the 05 ECU?
Keith
Keith
03-05 evo ECU wiring is the same. trust me the RRE wiring diagram is correct unless your shop is looking at the connector at wrong angle. why are you installing that on your evo anyway ??
So are we to assume then that certain pins (such as intercooler spray) on the 03-04's is just a dead pin on the 05's? I'm certainly not doubting RRE or anyone here for that matter I think most people just want some sort of final verification or 05 specific ecu pinout.
