"ti ti ti ti" at max boost
dude its nothing to worry about its the soelnoid, i had a apexi avr-r and it did that all the time its the sound of the solenoid activatind cus its achually a WELL built one not the chepey that you got with your stock evo.....
As long as you dont have knock, Or any of the evil signs of blowing up your motor run. The only boost gauge i trust is a map sensor. all these funky gauges that you find are worthless to me, just Xmas tree lights, that and A/F gauges
I have a GM solenoid on my car, its the sound of the solenoid allowing some boost to vent to maintain the pressure your target, its nothing to really worry about.. Its wise to run your boost no higher than 22psi on pump anyway..
If your concerned, you could run a compression test to be sure you didn't lose a head gasket, but I honestly wouldn't worry it sounds exactly like what my solenoid sounds like.
alpinaturbo
22
Sep 11, 2013 10:07 PM
Boost3dxEvO
May 11, 2007 01:23 PM
