Rev Limiter using engine cutoff
Old Mar 19, 2006 | 02:38 AM
ix_wagone's Avatar
I am looking for a way to make the ECU to generate engine cutoff or fuel-cutoff on demand by feeding a signal to the ECU. This is in order to implement a RPM limit by using a Launch Control (LC) device. What I am after is to connect the LC output to 1 of the ECU inputs and to pull it high or low to cause the engine to momentarily turn off. Probably using something like pin 92 which is the MAF sensor input to the ECU.
Old Apr 19, 2006 | 10:18 AM
speedjunkie2003's Avatar
wow.....when you figure this out lemme know :P good luck, sounds like a awesome setup once you get it all done and built...lataaa
Old Apr 19, 2006 | 07:21 PM
evohang's Avatar
yeah i wonder if thats my problem...im not even sure anymore on what my problem is...damn guys i searched and search....alll i can find is something ALMOST the same relating to mine....i installed a boost gauge to see if im over boosting and from what i see is that it is still reading 19 psi's but then i dont know if that explains the fact that it is having a fuel cut/ or whatever....im not so sure but if anyone could help please do so!!!
Stonewall
Oct 9, 2013 06:29 PM
Randal
14
Sep 24, 2012 02:33 PM
HDGamer
Sep 11, 2011 09:27 AM
nj1266
Mar 17, 2007 08:21 AM
SpecVSpeed
Aug 18, 2005 01:01 PM
