idle jump
Old Mar 30, 2006 | 06:21 AM
sleeperevo8's Avatar
Unhappy idle jump
I just added a 65mm throttle body and my idle jumped from 1000 to 2500 rpms messed with the idle screw no difference could it be with me AEM EMS ???how do i adjust it down?? i did the throttle calibration and my idle step 1/2 and 3/4 are on no luck any thoughts
Old Mar 30, 2006 | 09:11 AM
kf6ytc's Avatar
You need to calibrate the 'idle % vs Target table' , search for 'idle tuning' in the 'AEMPro User Guide V2.0'
-TJ
Old Mar 30, 2006 | 09:12 AM
nutrulz's Avatar
It's on page 72.
Old Mar 30, 2006 | 09:18 AM
nutrulz's Avatar
did you have to put the sensors on yourself, or did it come with the sensors preinstalled? Where did you get it from?
Old Mar 30, 2006 | 10:42 AM
came with sensors pre set and i swapped the sensor srom my old TB just to be sure that it was bad sensors but i'm checkin out page 72 now
Old Mar 30, 2006 | 11:19 AM
nutrulz's Avatar
You can't just swap the sensors. The TPS has to be calibrated in to position. if you notice the holes which you screw the TPS i to the throttle body are set up to be adjusted. I don't remember exactly what the numbers where, but you have to measure the resistance between 2 of the pins and then compare that to 2 other pins. It's actually pretty easy with a multi tester, but not something you can just eyeball.
Old Mar 30, 2006 | 01:47 PM
either way sensors made no difference
ryan010
Aug 16, 2016 05:18 PM
littlegif1
Jun 6, 2015 07:20 PM
Y.O.EVO8
Nov 5, 2009 01:09 PM
Tha one
Lancer Engine Tech
16
Feb 9, 2007 07:31 AM
Tha one
Lancer Engine Tech
Feb 9, 2007 06:14 AM
