Backfire after OLF upgrade?
Old Apr 2, 2006 | 10:47 PM
CT9A's Avatar
Originally Posted by Widebandphillip
pdx evo, did you ever try moving up the maf hz fuel cut up from 1700 to maybe 2500hz? That surely would have fixed your fuel cut problems. LCM is launch control, that will explain the bangs that occur after you step on the clutch and you let off the throttle.
LCM means launch control? Man, that makes so much sense. I'm going to go turn it off and see if that fixes the problem. Man do I feel dumb.
Here's another thing though, I get the launch control noises while I'm still under full throttle at times. I do have a tendancy to let my foot rest on the clutch pedal in between shifts. Is that enough pressure to engage the clutch switch, turning on the launch control?
If that's it, I'm a moron. Thanks for the help everyone.
Old Apr 2, 2006 | 11:40 PM
Widebandphillip's Avatar
I don't remember how sensitive the clutch switch was, but that's a very good possibility. I'd still do a boost leak test since it sorta sounded like you're leaking somewhere, thus causing a lot of fuel going into the engine and breaking up the spark (sounds like 2step). But yea, go turn off that launch control (put in 0 in parameters), and report back. If you still get that 2 step sound during full throttle, it is most definately a boost leak somewhere.
Old Apr 3, 2006 | 08:44 AM
PDXEvo's Avatar
It didnt take much to have the flat foot shifting thing go active while driving on my car. Just having your foot on the clutch will, sometimes, set it off. I only ever enabled that feature at the track.
Old Apr 3, 2006 | 12:26 PM
MalibuJack's Avatar
Oh yeah! I had that happen a few times when I had launch control active, the switch actuates so easily that any time your foot rests on the clutch pedal too hard it kicks in. I just assume nobody is using it right now, or ruled that out.
Old Apr 3, 2006 | 12:31 PM
MalibuJack's Avatar
Sorry I would have mentioned that after looking at the log.. If I saw you posted one.. Sorry..
Old Apr 3, 2006 | 05:35 PM
CT9A's Avatar
No worries Jack, thanks for the input.
I disabled the launch control, and sure enough, car is running beautifully.
I'm still trying to figure out the cut though. Do you think that my fuel cut like symptoms were related (I couldn't reproduce it today)? Or do you think that my turning off the MAF fuel cut and/or raising it to 3000 Hz just wasn't working for one reason or another?
Old Apr 3, 2006 | 05:52 PM
MalibuJack's Avatar
Well, I doubt its hitting 3000hz, but maybe you have the boost cut configured also?
Old Apr 3, 2006 | 06:08 PM
CT9A's Avatar
Boost cut? As opposed to fuel cut? I haven't seen anything in there about that. I'll have to take a look. If I'm not having the Utec control boost, is that even relevant?
kmartizdatruth
Aug 17, 2009 08:11 PM
Talon_66
Dec 10, 2008 04:53 AM
jlam
Mar 4, 2008 10:27 PM
anton406
Oct 28, 2007 10:16 AM
GOTMEALANCER
Lancer Troubleshooting
Jul 4, 2006 04:58 AM
