Shift Light Install
Old May 1, 2006 | 08:19 AM
Ultimate CC's Avatar
Shift Light Install
I have seen people use the shift lights with the UTEC via leds but I wasn't to sure how you go about hooking them up exactly. I would like to know if anyone out there has this done and if so how did you go about it. If not I guess I will be experimenting till I get it right. I don't see this being a very hard proceedure.
Dan
Old May 1, 2006 | 09:47 AM
MalibuJack's Avatar
Yeah I have one.. The UTEC switches to Ground, so you provide the 12v supply, and let the UTEC switch it on and off..
Old May 1, 2006 | 11:05 AM
aright cool and all you need to do is plug them into the UTEC, are there specific ports on the UTEC itself for this, its been a while since I have had the UTEC out of my car...
Old May 1, 2006 | 06:53 PM
nirvevo's Avatar
There is a detailed diagram in the UTEC manual on page #57 (make sure it's the current manual)
The supplied larger white molex connector has a red (#7 pin position) and a black wire (#1 pin position).
Hold the connector so that the wires are comming out the side that you are looking at, with the little clip on the top. the red and black wires should be to on the right side, with the red wire on top.
ground for light 1 goes to pin #9
ground for light 2 goes to pin #8
light 3 goes to pin #3 (in other words, right under light 1 pin#9)
All 3 power lines need go to a switched 12v source. If you want to, you can fab up a cable with (three) smaller wires for each light that splice into a larger wire that then runs to a power tap. That way you just have a single tap to deal with.
I tapped into the power line that runs to my turbo timer, so that I didn't have to put a 2nd tap into the OEM wiring.
Old May 1, 2006 | 06:55 PM
sweet, thats just what I need, will be going to store tomarrow for leds...
Old May 1, 2006 | 09:29 PM
MalibuJack's Avatar
Thanks.. You beat me to getting the info up but thats exactly what I was going to post for you.. It was really easy.. think of the UTEC's wiring as the switch..
Old May 26, 2006 | 09:18 PM
with the pins, did you just jam the wire into it, or did you buy the little connectors that go in it, I just went to install it, it has power but I think the connection for the ground via the UTEC is not working...
Old May 27, 2006 | 05:15 PM
MalibuJack's Avatar
I salvaged some pins to get it to work.. I took the pins out of an old ATX+12 PC Power supply connector..
Old May 27, 2006 | 05:20 PM
aright cool, I will try and find some then, I tried just sticking it in the pin but its not making a good ground...
Old May 27, 2006 | 10:03 PM
got it working finally, thanks for the help everyone...
chamboozy
Lancer Tranny/Drivetrain Tech
Nov 6, 2015 12:54 AM
Purevol8
Feb 27, 2012 09:14 PM
SRT4 to Evox
May 16, 2008 08:17 PM
Reed44
Sep 18, 2007 05:27 PM
GOKOU
Aug 7, 2004 02:09 PM
