Lancer Tranny/Drivetrain Tech Anything drivetrain related can be discussed here.
03 lancer es a/t wont shift
Old Dec 19, 2010 | 11:07 PM
chamboozy's Avatar
my brothers has a 2003 lancer es. the car today stopped shifting. its a automatic and feels like its stuck in 3rd gear. it shifts hard into reverse but will succesfully shift into neutral and drive. so starting off the car is in a high gear and wont down shift so its really sluggish until you get to about 40 so i am assuming that its stuck in like 3rd gear or so. well we have a check engine light so we got it pulled at the autozone and its a p1751 wich is for the a/t control relay. well in the underhood fuse box there is a relay that says a/t so i replaced it and let the car sit with the battery off for about 3 hours. The car was turned back on and the ses is stll on and the car is the same wont shift. now if you put the car in L gear i rides at 40 mph at like 2500 rpm the card idles fine also. so wether the car is n dive, L, 2, or 3 it acts exactly the same and it will not down shift. u gotta give it much gas to get up the driveway so i advised him to not drive it infear of blowing tranny until we can figure it out. any advice will be appreciated thanks in advance
Old Dec 19, 2010 | 11:41 PM
02-Lancer-Es's Avatar
Actually happened to me once also out of the blue . I just disconnected the battery and fixed it for some odd reason . Try checking the fuses and relays before going mechanical .
Gl
-Antonio
Edit very sorry did not read the whole post
Old Dec 20, 2010 | 09:10 AM
03lances's Avatar
Alright so just want to confirm you changed out this relay, 3rd from the rear. If so I suggest like 02 there to check all your fuses and let us know if you find anything. Also idk since I am manual but if that relay has the same numbers on it as the two next to it you can try switching them around to see if you might have gotten a bad relay for a replacement. Would not be the first time I have seen this happen.
Old Dec 20, 2010 | 10:57 AM
chamboozy's Avatar
well thank you for your help. I feel like an idiot and the fuse box undercover made me believe that the correct relay was in between the 2 others rather then on the outside... i just placed the correct on in and reset the battery and about to see what happens
Old Dec 20, 2010 | 11:19 AM
chamboozy's Avatar
hey so update... i replaced the correct relay and reset the battery and magically the ses was finally off and it runs great. my final question is wether or not there is a serious issue that has caused this or if the relay could just go bad at about 95k miles
Old Dec 20, 2010 | 12:19 PM
Mitsu.kid.02's Avatar
I dont think there is a serious issue, unless this happens again, i wouldnt worry about it. Sometimes things just go bad, ya kno?
Old Dec 20, 2010 | 08:58 PM
03lances's Avatar
+1 I would not worry about searching for a cause unless it happens again. Then I would start checking wiring connections.
Old Nov 6, 2015 | 12:54 AM
Crystal Carr's Avatar
Same thing 2002
what was the finally fix it I did the other stuff changed the switches out
Lightsaber
Apr 4, 2018 10:02 AM
jimbo74
28
Aug 28, 2016 07:47 PM
Mike W
84
Aug 19, 2016 08:36 AM
mrmiller
Mar 14, 2016 04:06 AM
blknblubkrdude
Jan 18, 2016 01:08 AM
