Evo IX reflash w/stock exhaust
Old Jun 28, 2006 | 09:41 AM
SinisterEVO's Avatar
I have an Evo IX and I was wondering what the gains would be with only a Flash (leaning toward dynoflash), no exhaust. I would like to keep the exhaust stock, for now. Also I see most people do a mbc and raise the boost to say 21psi, wouldn’t the reflash raise the boost already?
Old Jul 5, 2006 | 09:32 AM
305spool's Avatar
Boost is controlled by the wastegate, not the ecu. So you would need the MBC to raise the pressure to 21.
Old Jul 5, 2006 | 09:39 AM
dudical26's Avatar
Not exactly, Boost is controlled by the wastegate, which is controlled by the Factory Boost solenoid, which is controlled by the ECU. So ultimately the boost is controlled by the ECU. However, without modifying the stock boost lines the ECU can not boost much higher than 20 PSI or so. To get a more constant boost above 21 PSI a MBC can be used.
Old Jul 5, 2006 | 09:43 AM
itrsport.com's Avatar
Dyno Flash said that I would see 25-35 HP on my stock IX with a street tune flash. That's what I’m doing when Al comes to Chicago at the end of this month. I like how the car sounds now with the stock exhaust and don't want it any louder. The car is plenty fast for me now but for $300 I'm going to take the extra power.
Is there anyone else with a mechanically stock IX that had a reflash and can comment on their experience?
-Josh
streetturbo's Avatar
The Ix's stock boost is 20,7 psi, so it can boost 20 or so.
Old Jul 5, 2006 | 09:46 AM
1NastyEvo's Avatar
-Josh
https://www.evolutionm.net/forums/sh...d.php?t=209242
There ya go bud
Old Jul 5, 2006 | 09:48 AM
Warrtalon's Avatar
We had 2 guys in DC who did an MBC + base flash on their IXs and gained close to 50whp. They dyno'd before and after on the same dyno to verify.
Old Jul 5, 2006 | 10:57 AM
Well maybe that is one additional item I could invest in - a MBC - prior to my street tune with Al at the end of this month. Probably a good thing to have to increase power safely with a tune even though I'm running the stock exhaust? Is that correct? I'm not planning on ever doing an aftermarket exhaust.
I presume the MBC provides more tenability options to Al and maybe provides slightly more margined of safety/power? I've heard there are mechanical and electronic MBC - the electronic apparently can be more expensive but more accurate. If that's the case I go with an electronic version - what would one of those cost?
Any comments would be appreciated. Thank you.
-Josh
Old Jul 5, 2006 | 11:03 AM
Danny23's Avatar
stick with a mbc,hallman or forge unos. Al sells the forge and its a good unit so i would stick with that. yes Al can control boost with the flash but like it was stated already you would need the boost lines changed to go above stock psi.With the flash and mbc with the new lines you will see a big difference in power and especially driveability.good luck.
Old Jul 5, 2006 | 11:09 AM
Danny23 - Thank's for the info! What "lines" are you talking about? I'm unfamiliar with that detail. And aprox. what is the cost of the forge MBC and Lines installed? It seems like a no brainer to do those additions if i'm going to do the street tune by Al?
Old Jul 5, 2006 | 11:14 AM
Warrtalon's Avatar
The lines meaning your boost lines. They have to be modified to run increased boost when using the ECU to control boost. The ECU can't raise boost on its own. Installing an MBC is simple and shouldn't be more than an hours labor.
Old Jul 5, 2006 | 11:18 AM
thetox's Avatar
One word...Vishnu
http://forcedfours.com/showthread.php?t=214
In 90+ degree weather on a Dyno Dynamics...Bone stock car...runs like a champ
Stock HP: 226
Flashed HP: 270
Stock TQ: 217ish
Flashed TQ: just shy of 280
Old Jul 5, 2006 | 03:23 PM
Warrtalon's Avatar
A few more words - $750 vs $199 for nothing extra.
Old Jul 5, 2006 | 09:49 PM
Kc2Buk's Avatar
EVO 9 Flash results
https://www.evolutionm.net/forums/sh...d.php?t=182122
Originally Posted by AMS
Wow, these cars rock.
This EVO 9 is completely stock, not one modification.
stock is was laying down 261-262whp and 255-256 ft-lbs of torque.
With just tuning power jumped to 292whp and 293ft-lbs of torque!!
Boost spikes to 1.4 bar dropping to 1 bar by redline.
So here are the stats
HP before and after
262whp, 292whp after(30whp gain at peak)
256tq, 293ft-lbs after (37 ft-lbs gain at peak)
These results don't tell the whole story tough. Playing with the Mivec timing brings the turbo on boost quicker, and gives more power and torque in the lower to mid RPM range. Out of the 5 EVO 9's I've dyno'd I see a power dip around 7200rpm. With tuning this dip goes away and at 7500rpm I was making about 40whp more over the stock ECU program at redline.
[IMG]http://media.ams-evo8.com/pictures/tn_StockVsAMS.jpg[/IMG]
Completely stock as it came off the showroom floor.
Stock boost was 1.3 dropping to .9 bar. The only thing I changed was raising the boost by .1 bar (1.4psi). Stock it would spike to 1.3 bar and drop to .9 bar, now it spikes to 1.4 bar and drops to 1 bar.
-Martin
I'll have to ask Dan to be sure but I'd guess it's 93 octane, sweet, sweet Chicago winter 93 octane.
Evo IX Tuning Test - 91oct (330WHP)
https://www.evolutionm.net/forums/sh...d.php?t=181493
Originally Posted by Harman Motive
Thanks to Andy, we got our hands on an Evo IX for a few days of testing and development for our Harman Motive EvoIX Flash using EcuTek technology.
We dynoed the car bone stock, then proceeded to flash. We then installed a turboback exhaust system, 02 housing, and K&N panel filter and repeated.
All tests were performed the same day on the same dyno with the same car. All results are using the pump California 91 octane Andy drove in with.
Summary
Stock: 260WHP 253TQ - 17.15psi peak
Stock + Flash: 288WHP 280TQ - 22.71psi peak
Turboback: 301WHP 261TQ - 18.14psi peak
Turboback + Flash: 330WHP 301TQ - 22.37psi peak
http://www.harmanmotive.com/forums/e.../stock_v_flash
This graph compairs the car stock vs. Harman Motive flash. Only modifications were the reflash and boostMOD (stock hoses and solenoid remain).
http://www.harmanmotive.com/forums/e...ck_v_flash.jpg
This graph compairs the car with a full catless turboback vs. Harman Motive flash.
http://www.harmanmotive.com/forums/e...sh_v_flash.jpg
This graph compairs the reflashed stock car vs. reflashed with turboback.
Needless to say, I was very impressed with the performance of the car. It's right inline with my Evo8 MR w/ cams, intake, etc.
Each map was road tested following the tune to confirm proper A/F, boost, and timing profiles on the street. All tuning was conducted using "det cans" (knock sensor and amplifier connected to headphones) to ensure safe tuning.
Test Vehicle
2006 Evo IX MR GG - 1000mi ODO
Final Mod List
Espelir Downpipe
RNR Cat Delete
RNR Catback
K&N Panel Filter
Harman Motive EcuTek Reflash
boostMOD
Old Jul 5, 2006 | 09:53 PM
thetox's Avatar
So i guess u missed that big thread on the supra forums with samples of dynoflash maps? I know i didnt. That something extra is a quality tune, but Im not starting a war here. I posted up my results to show him what I got not to argue with you. I knew coming into this that you would say something after I posted but hey whatever.
