at what point are bigger injectors needed?
I'm setting up an upgrade path, and need to know if injectors are needed and what size for the plan I have...
currently my Evo is set up this way:
3" TBE
Injen CAI/upper IC pipe kit
Greddy Type S BOV
Dynoflash reflash
Greddy Profec B @ 22psi
Walbro 255 fuel pump
SAFC II (not tuned yet)
my next mods are planned out to be 272's and cam gears.
do I need to get bigger injectors before the cams/gears, or will I be able to get away with stockers?
3" TBE
Greddy Type S BOV
Dynoflash reflash
You will be fine with the stock injectors... they are either 550cc or 560cc (cant remember) which are beefy enough to max out your set-up using the stock turbo... for the upgrades you mentioned you wouldnt even need to upgrade the fuel pump, although a lot of people do its not necessary with those mild mods
