Stock Injector Resistance...
Old Jul 10, 2006 | 07:28 AM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
Anyone know offhand what the resistance on the stock 550s are? I'm sittin here goin through the AEM injector wizard and its showing 3 ohms for the stock injectors... If thats true then whats the big huff about the driver box to run low impedence aftermarket injectors? I'm FIC 850s that are rated at 2 ohms...When I get home i'll check it with a multimeter but I wanted to see if anyone knew already?
Old Oct 16, 2007 | 09:47 PM
blkdinan's Avatar
If the injectors are rated at 2 ohms you could have as much as a 7.2 amp load per injector on the driver box. You may want to make sure it can handle that load. The way to calculate this load is to use ohms law.
E / R = I
E = voltage- - - - - - 14.4v
R = resistance- - - - 2 ohms
I = current- - - - - - - 7.2 amps
for example
14.4 / 2 = 7.2 amps- - - - with your 850cc
14.4 / 3 = 4.8 amps- - - - with stock 550cc
That's a big difference!
Also beware most DVM's do not accurately measure resistance accurately below 8-10 ohms.
Old Oct 17, 2007 | 10:47 AM
cpoevo's Avatar
The Mitsubishi rpair manual says the resistance should be 2-3 ohms.
Taylor44t
Aug 13, 2017 12:00 AM
daveheit
Jul 21, 2016 01:14 AM
Taylor44t
Mar 19, 2016 01:06 PM
andymilonkis453
Lancer Engine Tech
Dec 8, 2009 05:56 PM
Scottp
Jul 9, 2002 03:02 AM
