Problem with car starting
Old Oct 21, 2006 | 06:03 PM
Charles B.'s Avatar
So I had just installed a CBE on my car today at my cousin's house. Everything went well with that.
However, my cousin wanted to try out his new OBD-II scanner on my car. He plugged it in and it showed three codes. One for MAS, one for IAT, and one for barometric pressure being low (I don't know the exact codes off hand). He decided to clear the codes and after that the car would not start. It turns on, it cranks, but it does not start.
Upon further investigation we checked and saw that the engine control fuse was blown. After replacing it with a new one and trying to start the car again the fuse blew again. My cousin also has another OBD-II scanner and both that and his new one were not recognizing the ECU.
Any ideas on what is going on? Any kind of help is greatly appreciated! TIA!
Old Oct 23, 2006 | 02:56 PM
Charles B.'s Avatar
Ok so one thing we did was disconnect the ECM put a new fuse in and turned the car ON. This fuse did not blow. We plugged the ECM back in and turned the car on and the fuse blew this time. Does this mean my ECM is fried?
Old Nov 3, 2006 | 01:31 PM
Illrunya's Avatar
TTT! Im curious to know what happend!
Old Nov 4, 2006 | 02:34 AM
Charles B.'s Avatar
pinched o2 wire. problem has been solved.
https://www.evolutionm.net/forums/sh...d.php?t=230901
s7alter04
Lancer Troubleshooting
Nov 20, 2023 06:22 PM
Evonv91
Mar 9, 2018 06:00 AM
Charles B.
Nov 2, 2006 03:15 AM
PVD04
15
Aug 29, 2005 12:22 AM
GotBoost25psi
Dec 5, 2004 04:21 PM
