Evo not starting
Old Feb 16, 2016 | 07:42 PM
Evonv91's Avatar
Evo not starting
Was driving the car normal beings it's a brand new build, when the car decided to just shut off. Pumps weren't working. Check all fuses and relays noting wrong.
Got it towed home and hard wired the pumps and now pumps work but injectors are not working and no spark. Plugged a scanner into it to see if it was the crank position sensor but the scanner will not communicate. Called my tuner over and now his laptop won't communicate to the obd2 ether. A 20amp fuse was blown under the hood so replaced that and still same issue.
Any insight to what's going on? Or where to start looking?
Old Feb 17, 2016 | 02:21 PM
Evonv91's Avatar
Bump for need to get the car driving again.
Old Feb 28, 2018 | 11:51 AM
idanoclo's Avatar
Was your issue ever resolved? Having same exact issue but I was warming up my car then it died.
Old Feb 28, 2018 | 01:48 PM
Project_Broke's Avatar
Check the Engine fuse.
Old Mar 2, 2018 | 03:20 PM
idanoclo's Avatar
I've check all fuses under the hood and left of steering column twice. Could it be an faulty ECU
Old Mar 2, 2018 | 06:28 PM
2006EvoIXer's Avatar
What was 20A fuse for under hood?
Old Mar 7, 2018 | 01:15 AM
TariqEvo's Avatar
Sounds like a faulty ecu, check if all the ecu cables are snug
Old Mar 8, 2018 | 09:03 PM
idanoclo's Avatar
picked up a used ECU. Car did start but ran like crap.
Old Mar 9, 2018 | 06:00 AM
When you hard wired pump, you probably bypassed low flow mode and make your pump run full power permanently. You are running rich when off boost.
phyzy
20
Feb 16, 2023 05:38 PM
kaj
16
Feb 12, 2012 10:40 AM
YuLost2x
Jun 21, 2011 10:54 AM
EvolutionTheory
10
Nov 15, 2009 06:25 AM
Kiartiger
Lancer Troubleshooting
Feb 28, 2009 12:12 AM
