Any solution for difficult cold starts?
Old Jan 18, 2007 | 06:40 PM
Syrihl's Avatar
Originally Posted by Mark S
You will have starting problems if it is to rich also you need it tweaked by someone with a proper wideband meter.
Mark
I have a wideband O2 meter installed on the car. The sensor is not heated up enough to read an A/F ratio when I'm starting the car in the mornings. Post-start it runs in the 10's and 11's at idle until the water temp comes up. Got any suggestions?
Old Jan 18, 2007 | 06:49 PM
CuLAZR17's Avatar
my brother had trouble with his car when he was living in canada in extreme cold temps. he got a block heater put in and it worked perfect.
Old Jan 19, 2007 | 01:30 AM
Mark S's Avatar
It should be leaner than that I would aim for 13.5 to 14 as it warms up, If you meter was warm for cold start I bet it would be in the 9's and this is where you problem is, remove some fuel from the WU table.
Mark
Night12000
Sep 28, 2015 08:03 AM
Syrihl
11
Feb 4, 2012 02:32 PM
andy hiralall
Nov 21, 2009 07:46 PM
500hpOnPumpEvo
23
Jun 29, 2008 09:22 PM
Grover
Australian Forum
Jan 15, 2003 07:47 PM
