hit wall while tuning last night (log attached)
Old Jan 12, 2007 | 07:09 PM
  #31
dryad001's Avatar
The UTEC uses the knock differently than the ECU, so what i would do is go back and start logging with the UTEC and Evoscan or Mitsu logger and see where the UTEC picks up knock but the ECU logger doesn't. Adjust the knock RPM accordingly in the UTEC parameters
Old Jan 14, 2007 | 06:16 AM
  #32
D's2004evo8's Avatar
looking to get rid of my utec....
Old Jan 14, 2007 | 07:54 AM
  #33
MalibuJack's Avatar
Not an appropriate location for this.. Post a new message in the For Sale section.
Old Jan 16, 2007 | 08:11 PM
  #34
Mercenary3's Avatar
Originally Posted by DCsleeper
EvoTech,
MBT 'maximum best timing' from my understanding the point at which timing does not improve power but hampers it....
Close, MBT stands for (M)inimum timing for (B)est (T)orque. An odd acronym, I know, thats why so many people mess it up. The reason why "minimum" is there is that becasue you want to run the least amount of timing advance possible to get the best torque possible. So if you make x ft lbs running 15 or 16 degrees of spark (and x is the most possible), MBT is 15, becasue it is the "minimum timing". You see? You want the minimum because you get the least peak cylinder pressure, less chance of knock, letc. Your understanding is correct, there is a point where advancing spark timing does not give you any more torque. Basically, there is too much pressure building before TDC to get further increases in torque.
That being said, you are most likely not at MBT on premium pump gas. You would have to run C16 or something similar to see MBT at most rpms or running very low boost. With turbocharged cars, it is usually best to trade off a bit of timing to allow an increase in boost pressure, especially on pump gas octane levels. Meaning, turbo cars tend to be happiest running less timing than MBT, but with slightly higher boost than you could if you did run timing at MBT.
Old Jan 18, 2007 | 02:48 PM
  #35
DCsleeper's Avatar
Mercenary,
Thanks for the correction....your explenation makes perfect sense. My theory was sounds just did not have it exactly right....good thing that all through my engineering classes I got partial credit.
Miller_x
Mar 22, 2012 04:41 PM
mchristian
Aug 18, 2011 10:47 AM
mikesevo8
18
Mar 1, 2009 07:46 PM
Mad_SB
Jun 23, 2006 06:56 AM
EMR8
Jun 21, 2006 06:25 AM
