Apexi AVCR settings help
Old Mar 4, 2007 | 01:35 PM
EclipseMblue's Avatar
yes i searched the forums i found alittle useful information but its still not to clear to me. Im trying to set my avcr so i can run 21psi I see the screen were it says boost so i set it to 1.45kg/cm2 but below that it says duty ?? which i dont know what that does. Same thing with gear judge i dont know what that is for. Can anyone just tell me what i have to set the ebc to run 21psi. Thanks
Old Mar 4, 2007 | 02:08 PM
gaulrich2003's Avatar
1kg/cm2 equals around 14.75 lbs of boost, so you are a little over 21lbs. The duty has open and closes something but I am not sure what. If the percentage is to high you will overboost. If the percentage is to low you wont boost enough. I would not mess with gear judge or anything. My car is set at 1.7kg/cm2(25lbs) and 54% duty. If you get it dialed right it will hold great. I found it best to test the duty in 4 gear. Good luck!! Send me a PM if you have more questions.
You can also check out the subaru forum, nasioc, they have some good write-ups on their website about it.
Old Mar 5, 2007 | 09:31 AM
spoolint78's Avatar
you have to fiddle aroudn with the duty.
If tis to ohigh it will overshoot the pre set boost level as mentioned by gaulrich2003.
EvoDan2004
28
Oct 25, 2013 07:58 PM
germanracing
10
May 4, 2010 11:28 AM
SmurfZilla
Sep 23, 2009 02:57 AM
SEEnoEVO
Jun 4, 2009 04:14 AM
Claudius
May 10, 2006 06:41 PM
