SES "Engine Overboost Condition"?
Old Apr 18, 2007 | 06:45 PM
bhamEVOguy's Avatar
got the good ol SES light on again n this time it threw 2 codes P0300 which m not too worried about but the other 1 is:
P234 Engine Overboost Condition
Anybody have any idea of what could have caused this or if u have had this problem to ur car. any solutions?
oh n the mods i have are
--Adapter Air filter
--Catdelete
--XSPower Intercooler n LICP
thanx
--Seth
Old Apr 18, 2007 | 06:46 PM
DRFTKNGG's Avatar
Boost leak, Sudden drop in air temp...?
Old Apr 18, 2007 | 06:53 PM
bhamEVOguy's Avatar
found another thread about this but the code is different. its P230 on the same year.
https://www.evolutionm.net/forums/sh...oost+Condition
Old Apr 18, 2007 | 06:57 PM
bhamEVOguy's Avatar
boost leak. but the code shows overboost. thats kinda the opposite if m not mistaken. isn't it?
Old Apr 18, 2007 | 06:58 PM
SilverEvo8owner's Avatar
hve you hit boost cut?
Old Apr 18, 2007 | 07:03 PM
mikesevo8's Avatar
DTC P0234: TURBOCHARGER WASTEGATE SYSTEM MALFUNCTION
TECHNICAL DESCRIPTION
• The ECM checks that the engine is not overcharged by always monitoring intake air volume.
• The ECM protects the engine by shutting off fuel when an overcharged condition is detected.
DTC SET CONDITIONS
Check Condition, Judgment Criteria
• Volumetric efficiency of 210 − 230% for 1 second.
TROUBLESHOOTING HINTS (The most likely causes for this code to be set are: )
• Turbocharger wastegate actuator failed.
• Charging pressure control system failed.
• ECM failed.
Old Apr 18, 2007 | 07:34 PM
sekula's Avatar
check your fuel and boost cut and are you hitting any of those two cuts?
Old Apr 19, 2007 | 09:58 AM
bhamEVOguy's Avatar
DTC SET CONDITIONS
• ECM failed.
sorry but that is the rite code. P0234 Engine Overboost Condition. I had it scanned from a local autostore.
and i'll check all the lines and hoses today.
Old Apr 19, 2007 | 10:01 AM
EV0lut10n_8's Avatar
DTC SET CONDITIONS
• ECM failed.
Hey, got a link to a site where you found this info?
Old Apr 19, 2007 | 03:06 PM
mikesdad's Avatar
That was copied that direct from the evo manual...
Hey bhamEVOguy - the DTC code is the same.
Sorry if the official title in the evo manual doesn't match the verbage in a hand held scanner...but if you'll notice,
the symtoms describe an overboost condition, most likely caused by the fact that the WG didn't
open properly for some reason.
Old Apr 25, 2007 | 02:59 PM
TylerO@WORKS's Avatar
Hitting boost cut is from the MAF seeing to much airflow 99% of the time.
Your intake doesn't let the MAF work the way it was designed to. The Stock air box is very good an regularizing the air flow so the MAF can get a good reading.
Your exhaust mods also let the turbo flow more air, and peak boost (flow) is higher.
The combination of these two mods, with out a proper tune, commonly causes this issue.
A boost LEAK has the same effect and will throw the same code. Its not reading the pressure going into the motor or even the air going into the motor. All the ECM knows is how much air the MAF is flowing. Its critical for its signals to be accurate or the car will run like crap and/or hit boost cut.
Hope that helps!
Old May 4, 2007 | 01:32 PM
bevolucion's Avatar
same thing happen to my evo, when i put in a ebc. it was all fuel cut. I got that taken care of by setting the ecu to eliminate the fuel cut. If am not mistaken it happens when you overboost and the ecu send the signal to stop fuel intake, all because your running more boost than stock. please correct me if i'm wrong
Nick919
14
Aug 26, 2017 11:06 AM
Celica2EVO
Nov 6, 2007 08:41 PM
TINMAN
Jan 15, 2007 10:55 AM
eponti
18
Sep 30, 2006 02:55 PM
CrazyIvan1978
Jan 12, 2005 02:36 PM
