Boost leak test
Old Jun 29, 2007 | 03:26 PM
EVIL MR's Avatar
Originally Posted by 6-speed
Correction stock turbo inlet size is 2.5".
my bad
Old Jul 1, 2007 | 07:59 AM
dan l's Avatar
Originally Posted by EVIL MR
there is no way in hell you can do a boost leak test at 45psi, 1st you will push everything open and you will not be able to tell if there is a leak or what. 2nd the diff is that when you drive the car you are using the air but when it of it's just lot of hot air like you.
WTF?
So your telling me that I haven't boost leak tested my personal car to 45psi. Your telling me that I haven't done something that I have done numerous times? Why don't you go back to your playstation games now little boy, mommy is calling.
Old Jul 1, 2007 | 02:37 PM
EVIL MR's Avatar
you are so funny I forgot to s889 on you
Old Jul 1, 2007 | 02:43 PM
EVOL2003's Avatar
Originally Posted by jyndrus90
Ok so my buddy wants to do one. Has stock piping etc. Only a MBC that would affect boost. Anything needs to be plugged etc? WHats the turbos inlet size? Im not new to testing since I tested all the time on my srt-4 just never on a evo. Can someone steer me in the right direction.
this worked for my buddies dsm.....
http://www.vfaq.com/mods/ICtester.html
EVOL2003's Avatar
Old Aug 3, 2007 | 10:11 AM
monsterevo6's Avatar
in my case, my car was specially good and fast, then one day to another , something change, donīt know what, sometime i got boost other times i got alot, put donīt feel nothing. my car in 16psi, feel the same as 24psi, and that is not normal, i only heard the turbo louder but do not go.
the boost controler will make your turbo charge no matter what, he will do it, but we test the pipes we put pressure on it, and we find out that the 18psi the blow off was leaking, so the boost control can take the turbo up a peak of 24psi, but it opens so that air the maf is no reading it, no good.
IT THIS HAVE ANY SENSE.
JEFFREY
cmb70
Jun 25, 2015 08:59 AM
Wirk
Oct 4, 2012 04:31 PM
governmule
May 4, 2011 09:05 AM
BCOZEVO
Aug 10, 2008 10:10 AM
urslo4n8
Apr 15, 2008 07:31 PM
