EvoScan and 2G DSMs
Old Jun 25, 2007 | 09:08 PM
recompile's Avatar
EvoScan and 2G DSMs
I have a bunch of friends with 2G DSMs, and I've been logging their cars with EvoScan... A couple have DSM link, a couple others have an SAFC. I have a bunch of questions, if anyone can answer...
1) Is KnockSum when logging a 2G DSM comparable to logging an Evo? ie., 0-2 is mostly safe, 3 or more you're in danger? One of the guys has straight 1 KnockSum from the second he gets on WOT to the second he lets off
2) Is OctaneLevel when logging a 2G DSM comparable to logging an Evo? Same guy as above has OctaneLevel go from high 90's down to as low as 15 at WOT
3) If I was to tune AFR with EvoScan without a wideband, what do I log for narrowband and how do I make use of narrowband numbers?
4) What is the typical timing map for a 2G DSM? Should cruise be similar to an Evo (30's) and then WOT ramp down to ~4 at peak torque and up to ~12 by redline ?
Thanks in advance.
Old Jul 1, 2007 | 09:30 AM
dan l's Avatar
I was not aware that you can log the 2g dsm's with evoscan. Can you also log 1g dsm's?
The 1g has a knock count from 0-43. The 2g I believe is the same. For every 3 counts of knock the ecu pulls 2 degree of timing. More precisely it pulls 90/255 degrees of timing for every 1 degree of knock. When the car is above a certian temperature it pulls 1 degree. When the car is too cold it also pulls 1 degree and adds some extra fuel as well. On a stock motor under 10 counts is "safe". It is ideal to tune cars as close to 0 as possible but this often doesn't result in as much power and dsm's tend to knock a lot more than evo's. 4 at peak torque to 12 up top sounds like he's running his injectors pretty hard or knocking a fair bit. You can't really tune on a narrowband. They are too slow and vary from car to car. LC1's are only 200 bucks anymore so its really not worth the effort to even try.
Old Jul 1, 2007 | 09:33 AM
recompile's Avatar
Thanks for the update.
I was able to find these, which are stock 2G DSM Maps. The left column is engine load (high to low) and the top row is engine speed
Old Jul 1, 2007 | 11:06 AM
Dennis F's Avatar
I could run quite a bit more timing on my 2g. I think I had it peak at 20 degree's with no knock on a 20g/supporting mods, 44-45 pounds per minute according to DSMLink.
I would have to say though, 10 counts is real bad, I am pretty sure it does not go to 43 or whatever like the 1g.
Old Aug 15, 2007 | 06:41 PM
siceclipse's Avatar
im having trouble connecting my 95 GSX up with the evoscan software.
i dont have the supplied cable, im using the Tatrix(sp?) cable.
any ideas?
Old Aug 16, 2007 | 03:32 AM
recompile's Avatar
Try setting the timeout to a high value... I can't remember what it is by default, but if you triple or quadruple it, that should work.
3VOLUTIONIST
Apr 24, 2015 09:52 PM
richardjh
May 24, 2013 01:53 PM
sykou
Lancer Engine Management / Tuning Forums
11
Sep 10, 2008 12:34 AM
4g63_guy
Feb 20, 2008 04:53 PM
