blow-through MAF
Old Jul 10, 2007 | 02:12 PM
03evo**'s Avatar
What is blow..??
Old Jul 10, 2007 | 02:15 PM
03evo**'s Avatar
srry for the newb question not a bov right.??
Old Jul 10, 2007 | 02:19 PM
V.8MR's Avatar
Originally Posted by 03evo**
What is blow..??
Things you put in your nose.
Old Jul 10, 2007 | 02:21 PM
sonicnofadz's Avatar
Old Jul 10, 2007 | 03:06 PM
VRSF Tiago's Avatar
Is it even possible to setup the stock maf in blow through?
Does anyone know what the HP record for an evo using the maft?
Old Jul 10, 2007 | 05:11 PM
Tuner@Swift's Avatar
I don't think Karmann Vortex mass air sensors work that well in a blowthrough setup, too much turbulence will cause sporadic readings.
I don't know what the record is, but I am @ 400hp/400tq on the stock turbo using the maft pro and 3" GM MAF sensor.
Old Jul 10, 2007 | 05:38 PM
EvoJoeIX's Avatar
its definitely possible, but like someone said before, the boosted air might be to turbulent for the sensor to accurately get readings
not sure if the one guy is serious or not.....but:
a blow-through maf set-up is when the MAF sensor it ran in the upper intercooler pipe instead of in the intake to the turbo
Old Jul 10, 2007 | 06:00 PM
Here's what my setup looks like under the hood. Notice the MAF placement, the full 4" intake pipe and the piping (dejon tool).
Old Jul 10, 2007 | 06:22 PM
94AWDcoupe's Avatar
its been done to the tune of 600whp. I would blow through the stock maf ten times before using a gm setup. I have tuned a few of the gm setups. i am not at all impressed with the conversion tales. Getting the a/f spot on in all conditions is lost when you convert to the gm setup.
Old Jul 10, 2007 | 07:08 PM
VRSF Tiago's Avatar
So you're saying you'd prefer to use the stock maf in blow through?
I understand the downsides of running blowthrough such as innaccuracy when comparing to the normal maf, but I've never heard or seen anyone even attempt to run the stock maf in blow through.
When you say you'd "blow through the stock maf ten times", I read it as you'd prefer to run the stock maf in blow through rather than the GM, but I've never seen anyone do it before.
I'm not trying to be a dick, I just want to know if anyones actually put the stock maf in blow through and I wanna see how it performed.
Old Jul 11, 2007 | 03:00 AM
Ev0cRaZy's Avatar
Blowthrough setup works great, I made over 500+whp on it.
A local friend made 580 somethin
Old Jul 12, 2007 | 06:06 PM
VRSF Tiago's Avatar
Was there a huge difference in the tune before and after the maft? I'm curious as to how accurate the conversion actually is from the stock to the maft.
Do you have any engine bay pics?
Old Jul 12, 2007 | 06:09 PM
Ev0cRaZy's Avatar
I didnt tune without, but I did notice a 400 or so rpm quicker spool, and defiently felt great on the butt dyno
Old Jul 12, 2007 | 06:13 PM
sikrsix's Avatar
So you just extended the wires for the maf plug and used 2 adapters to run your oem maf in the UICP? I assume the maf should be put before your alky nozzle..
Old Jul 12, 2007 | 08:53 PM
VRSF Tiago's Avatar
Are you using the maft or the maft pro?
