After Mivec Tune (Service Engine) Light turn on
Old Oct 7, 2007 | 08:57 AM
PHI_HO1's Avatar
I just install the HKS Mivec cam in couple weeks ago, and have it tune and dyno. The car pull very smooth and gets good number. Sadly the Service Engine light turn on two day later. The P0300 code "POP" up and I just want to know what will happen with the engine when that code pop up. Good or Bad or Critical codition for the engine, my tuner can't fix it. So now i'm trying to adjust the timing a little bite with a friend hope fully it go away. I need some good advice on this. I need experience help on this case. If i load the stock map of and Evo 9 in will it go away?
Old Oct 7, 2007 | 10:17 AM
nj1266's Avatar
Originally Posted by PHI_HO1
I just install the HKS Mivec cam in couple weeks ago, and have it tune and dyno. The car pull very smooth and gets good number. Sadly the Service Engine light turn on two day later. The P0300 code "POP" up and I just want to know what will happen with the engine when that code pop up. Good or Bad or Critical codition for the engine, my tuner can't fix it. So now i'm trying to adjust the timing a little bite with a friend hope fully it go away. I need some good advice on this. if anyone like to see the map I can pm it. I need experience help on this case. If i load the stock map of and Evo 9 in will it go away?
WOW...That is the same experience a friend of mine had with his Evo 9. He had it tuned by a famous SoCal tuner and after the tune he had a P0300 code, multiple misfires in all cylinders.
I flashed his car back to stock and it has been a week and the P0300 did not come back. Flash you car back to stock AND reduce your boost to stockish levels. Clear the code with a reader and it should go away.
PM me if you need any help.
Old Oct 7, 2007 | 10:22 AM
PHI_HO1's Avatar
hey is there anyway you can send me the stock map of a Evo 9, my email is phi_ho1@yahoo.com please i need it really bad bro.
Old Oct 7, 2007 | 10:24 AM
PHI_HO1's Avatar
Old Oct 7, 2007 | 04:56 PM
RazorLab's Avatar
Are any numbers in your Mivec map higher than 30?
Old Oct 7, 2007 | 10:02 PM
PHI_HO1's Avatar
some of them
Old Oct 7, 2007 | 10:22 PM
GST Motorsports's Avatar
some of them
Then that could be part of the problem. You can input above 30 in the mivec map but it doesn't do anything and can also trigger cels or even mess with the mivec itself.
I would recommend bringing them down to 30 or under.
Old Oct 9, 2007 | 05:00 PM
tephra's Avatar
yup *30 is the max otherwise yellow lights for you!
Old Oct 9, 2007 | 06:58 PM
PHI_HO1's Avatar
i try to do it already. did it like for time each time i lower 2 dregee and the total is 8 in the flash but still no luck.
Old Oct 9, 2007 | 07:18 PM
tephra's Avatar
what do you mean total 8 in flash?
just reduce any mivec numbers higher than 30 to 30...
Old Oct 9, 2007 | 07:24 PM
V8Hunter's Avatar
Contact John at Jestr Tuning...he will ease all your pain.
Old Oct 11, 2007 | 08:36 AM
Mr. Evo IX's Avatar
What ignition timing are you running at idle to make the cams idle?
+1 on changing any mivec over 30 to 30.
Old Oct 13, 2007 | 07:18 AM
PHI_HO1's Avatar
I'm going back to stock flash now. will see wat happen
mr2turbo18
Apr 21, 2014 05:35 PM
GGEvoNine
Nov 23, 2013 10:18 AM
impact blue
Feb 6, 2013 06:32 AM
LAY6C
Toronto Lancer Club
Apr 2, 2012 08:18 AM
Poondoggs
Nov 5, 2009 10:49 PM
