Unusual load reading observed during datalogging
While doing some ECUFlash Tuning (Road tune) and logging with EvoScan I had a single cell (outlyer) that registered a calculated load of 380. No boost spiking was witnessed and the next cell was linear with the cell previous to the outlyer. The highest legitimate load that I have witnessed to date is 272.
Any thoughts or possible explanations for this? Bad Bit or something
With 2-byte load you'll see spikes and dips every so often. They usually don't come with knock though. 99% of the time it's just a problem with how the bits are lined up or something, but I'm with Mellon ... definitely check the AFRs for signs of a misfire. If everything but load is correct then there is no need to worry ...
Pitside
Apr 29, 2014 04:02 PM
