I want a better tune
I'm glad Bryan is helping you out...he knows his stuff
By boost from gear to gear is different..which I'm told is normal....different gears have produce different loads which produce different boost spikes.
In 3rd,4th,5th...my boost peaks at around 21.5 to 23.3 psi (depends on how cold the weather is) at around 3500 rpm and that lasts only till about 3900-4000 rpm when it tapers off to around 19-18psi.
hope that helps
hope that helps
hope that helps
hope that helps
If you are installing the test pipe this weekend then why are you running a stage 2 map now?...you did read in the notes that stage 2 map was for a TBE....that could be a problem...
But after some help from Razorlab I've gotten my boost peaking where it should be and holding relatively well around that range
68wsteve
Dec 13, 2010 10:18 AM
sti"izzle"
Sep 21, 2010 01:31 PM
LakerRaider
15
Jun 24, 2010 10:59 PM
