Engine cut out
Old Feb 10, 2008 | 06:04 AM
Evo TME's Avatar
Engine cut out??help!!!!!
please help
i drive an evo 6 tommi makinen edition and im worried that somethings wrong with my engine
the car shuts off for a split second when i punch the throttle to the max and noticed that when ever my boost gauge reaches 20 psi the car shuts off for a split second with a big bang sound, iv been told that since my car is entirely stock the ecu cant handle 20 psi and since its winter the psi runs higher and reprogramming the ecu should solve the problem. it only happens when the psi reads 20 and cuts out the engine as a safety procaution i have been told....
any idea what might be causing this cut out???
cheers
Old Feb 11, 2008 | 05:09 AM
honki24's Avatar
That's fuel cut because your boost has exceeded the "safe" limit as programmed into your computer. You need to remove the fuel cut via reprogramming your ECU somehow (not the same as for 7s/8s/9s). The ECU+ is an amazing piece of equipment, but the only way to get rid of that is to:
A. lower your boost
B. Get a standalone (like AEM EMS)
C. somehow flash your ecu to get rid of that.
Old Feb 11, 2008 | 07:32 AM
rolly1818's Avatar
Registered User
nothing too technical, it can be done useing ECuflash, very simple.
you are getting a fuel cut when ur boost esceeds a predetermined value. feels like the car is dead!
so ANNOYING!
nothing too technical u got a MBC or EBC?
Old Feb 11, 2008 | 09:07 AM
Evo TME's Avatar
nope dont even know what a MBC or EBC is but for the help guys really appreciate it....i guess i just need to somehow change the ECU or reprogram it
Old Feb 11, 2008 | 12:21 PM
rolly1818's Avatar
Registered User
u have a manual or electronic boost controller?
is the car stock? what mods u got?
Old Feb 12, 2008 | 07:03 AM
Evo TME's Avatar
its all stock, all i have is a turbo timer and a boost gauge not that its related to this
Old Feb 13, 2008 | 02:46 AM
rolly1818's Avatar
Registered User
hmm weird ,,just turn down ur boost slightly as i said above when ur boost is too high the ecu reads it and cuts fuel...car seems dead..
if u lift off the throttle for a second and then go back on the throttle u will get back power,, that is until it happens again..
this does not happen everytime u go X to board (WOT) right? only sometimes?
PM me if u want further info i can help.
Old Feb 15, 2008 | 05:04 AM
Evo TME's Avatar
its alright i think i got the answer i was looking for, as long as theres nothing damaged that results in this cut its cool with me
thanks for the help guys really appreciate it...the weather is getting hot again so i dont have to worry about my boost levels hitting 20 cuz its gona be too damn hot although feeling that kind of power felt real good
evoviiihan
10
Oct 22, 2016 10:00 PM
D1andonlyantman
Nov 11, 2015 12:53 PM
caliraised
Feb 18, 2015 09:03 PM
bmojito
Jul 7, 2008 01:36 PM
