P0104
Old Apr 6, 2008 | 08:26 PM
phabaznbro's Avatar
P0104
I'm throwing this code and another one i belive 0103 for low and intermitent signals from the MAF. Any idea what could be causing this? I just did install the intake in my sig but I've gotten it tuned already.
I cleaned the MAF today. Whats the best way to check for leaks in the take pipe? I did notice I am getting more flutter than normal from my DV since the install.
The MAF wiring is still wrapped up from the factory and seems solid as hell.
Any ideas?
Old Apr 6, 2008 | 09:17 PM
phabaznbro's Avatar
anyone?
Old Apr 7, 2008 | 10:00 AM
phabaznbro's Avatar
any ideas people? even on the best way to check the intake for leaks? chances that the MAF has already malfunctioned?
Old Apr 7, 2008 | 03:23 PM
phabaznbro's Avatar
Old Apr 7, 2008 | 04:01 PM
[EVO]Cookie's Avatar
If you just cleaned the MAS and it worked fine before I would think you might of damaged it or the wires.
A code P0103 may mean that one or more of the following has happened:
The MAF may be disconnected, or a wiring connection may be bad
The MAF sensor may be damaged
The vehicle computer may be faulty (very rare)
A code P0104 may mean that one or more of the following has happened:
The mass air flow (MAF) circuit is incomplete (broken / frayed wire, etc.)
There is an air leak in the intake system
Also if you removed your DV check to see if its flowing the right way. Also check out your vacuum lines off of your maf pipe make sure you ran the lines right or caped the ones not in use. If your using filter oil don't over oil it or you will have to clean it all over again. That filter oil can foul the MAS and cause that code.
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
khalid.alghawas
May 16, 2013 10:08 AM
Appauldd
Apr 16, 2008 06:58 PM
Aby@MIL.SPEC
10
Dec 4, 2006 12:02 PM
dubbleugly01
Oct 5, 2006 09:32 PM
