n00b question
Old Jun 21, 2008 | 11:48 PM
MitsoKid's Avatar
n00b question
Ok, I own a 2005 Evo 8 with intake, exhaust, hks 262 cams, precision injectors, at 21psi. I am currently using a Turbo XS UTEC to tune and my last dyno was 392awhp at 24psi.
I am not to happy with the tune because it's running way too rich at lower rpm's and a little lean at higher rpms, its robbing power and i'm worried about overheating at the track.
i have a good understanding of engines, fuel systems, ect. but i have never actually tuned a car with software before.... am i in over my head or do you think i can manage if i get walked through how to use the software?
i just don't want to F*** up somehow you know, but i don't trust tuning shops in my area and can't afford to send it off.
any help or advice will be greatly appreciated!!!
Old Jun 21, 2008 | 11:53 PM
slicedbreadno2's Avatar
what kind of dyno did you run at to get that power?
also I'd stick with the stock ECU and get a mail in flash by some of the vendors on here. Is this Turbo XS UTEC an Engine management system?
also get an A/F ratio gauge.
Old Jun 22, 2008 | 12:00 AM
TurboTim06's Avatar
to tune yourself you need to have a real good understanding of air/fuel ratios, timing adjustments, definatly a lot of learning involved...check out the write up in the ecuflash forum on here its pretty good at explaining things in basic form
Old Jun 22, 2008 | 12:02 AM
MitsoKid's Avatar
i have an Autometer narrowband A/F gauge and the Turbo XS wideband A/F gauge built into the UTEC. A simple mail-in flash won't get me to where i need to go, and the UTEC is one of the more advanced piggyback systems in that it allows you to adjust timing, injectors, knock sensing, boost, ect. with a few keystrokes
Old Jun 22, 2008 | 12:07 AM
markymark1082's Avatar
+1 on the tuning forum.
https://www.evolutionm.net/forums/fo...play.php?f=179
Old Jun 22, 2008 | 12:09 AM
MitsoKid's Avatar
oh yea, forgot to mention i got those hp #'s on a Mustang Dyno in 30 degree weather back in Jan. prolly more like 330awhp realistically when you factor in humidity, heat, ect.
Old Jun 29, 2008 | 07:31 PM
gmore84's Avatar
yeah.. that's true.. on this forum. you can do eflashing with a few tuners on here.. some are very well known for just a 100 dollars until you're satisfied.. lol.. 4wstuning is good.. jestertuning is good.. theres a bunch all here.. and they all will like ur buisness..
Old Jul 5, 2008 | 04:17 PM
Mellon Racing's Avatar
392 awhp at 24psi with a stock turbo evo 8 turbo and no head work and tiny cams, that sounds awfully high unless you've got high octane/timing
anyway, I have links to the software and a video tutorial for how to download the rom etc... might help you get started www.mellontuning.com
Boosting88
May 2, 2015 02:12 PM
JHS VIII
Mar 5, 2012 08:48 AM
Braydo25
Lancer Engine Management / Tuning Forums
Jun 2, 2010 07:52 PM
Green_Bandit
Oct 10, 2007 12:04 PM
BlackonBlack2
10
Aug 6, 2007 06:36 PM
