which wideband to use for logging and tuning
Old Jul 23, 2008 | 11:59 AM
slvevo8's Avatar
I am currently setting myself up for some basic do it yourself tuning, and i need some advise on my choice of wideband. I have a laptop on the way, I will order the obd cable when i get paid, and can download evoscan and the tuning software once theo computer gets here. In the meantime, I have my dash tore up so i can put some gauges in. One of them will obviously be a wideband. I would like to know what wideband will work the best for what I am trying to do. I want it to run well, and not need to be calibrated every 30 seconds. Also, what else will I need besides the wideband gauge and o2 sensor? Is there someother component that links the wideband to my laptop? Any help is appreciated!
Old Jul 23, 2008 | 12:43 PM
compscibOi's Avatar
http://www.zeitronix.com/Products/Products.htm
/thread
Old Jul 24, 2008 | 09:55 AM
MR Turco's Avatar
AEM Uego. Cheap, works great, no calibration needed, major loggers work with it.
Old Jul 24, 2008 | 11:00 AM
lemmonhead's Avatar
AEM Uego for me, cheap and evoscan logs it fine.
Old Jul 24, 2008 | 12:41 PM
racer135's Avatar
AEM UEGO. Cheap, no calibration. Works with EvoScan and can be installed in a 52mm gauge pod.
Old Jul 24, 2008 | 01:43 PM
magyar86's Avatar
im using the aem uego as well, works very well and logs perfectly with evoscan..
Old Aug 14, 2008 | 11:03 AM
slvevo8's Avatar
i am getting the innovate lc-1 with a titan motorsports af gauge. i hope i like it.
Old Aug 14, 2008 | 11:21 AM
Mellon Racing's Avatar
I like the lc-1
Old Aug 14, 2008 | 11:23 AM
slvevo8's Avatar
how hard is it to hook up, harder than the uego correct? the uego from what i understand is a all in one unit, while the lc-1 needs to be hooked up, then you can hook a gauge to that. am i right?
Old Aug 14, 2008 | 11:44 AM
Ambiguous's Avatar
Im Stuck between the LC-1 and the AEM UEGO... I have heard that the LC-1 has to be constantly calibrated and can be corky sometimes.
Old Aug 14, 2008 | 11:45 AM
yes I did the LC-1 + DB gauge from www.tunertools.com and used my discount code for being a member or www.racevideforums.com there is some minor wiriing involved (ground/power) and I picked up a serial to usb converter so it would plug into my laptop and work with evoscan/ecuflash.
Old Aug 14, 2008 | 11:49 AM
slvevo8's Avatar
I will need something besides a traxis cable to hook the wideband to my coputer with the lc-1?
Old Aug 14, 2008 | 11:54 AM
you'll need two usb ports
1) tactrix cable from ODB port to the laptop
2) serial to usb adapter to connect the lc-1 to the laptop
Old Aug 14, 2008 | 12:15 PM
alloutDSM's Avatar
does the lc1 need calibration? i thought it didnt...
Old Aug 14, 2008 | 12:30 PM
yes it does but I don't do it the way they suggest:
I get up to ~ 50mph, leave it in 5th or 6th gear then let off the gas, the engine becomes a big air pump and I press the button to calibrate it...presto
