GSC S1 cams, Walbro?? Should I buy that??
Old Jul 25, 2008 | 08:56 AM
mscorei's Avatar
Question GSC S1 cams, Walbro?? Should I buy that??
Hey, I have the mods that are listed below, and I'm willing to upgrade. I bought Denso IKH24 sparg plugs ( 1 step colder) and willing to buy GSC S1 cams, from a friend of mine, are used only a few miles, cause he is upgrading also. Should I buy from him or buy new ones?
For my current setup plus spark plugs,S1 cams and ecu tuning, do I need also a Walbro fuel pump? Please, I need some advice. Don't forget to mention if buying used cams is OK.
Old Jul 25, 2008 | 12:18 PM
mscorei's Avatar
anyone?
Old Jul 25, 2008 | 12:26 PM
sk8terdude929's Avatar
Used cams are fine as long as you trust the seller and the cams are in good condition. i would get a walboro, others may say that you dont need one yet but why take any chances; you can get them for under 100$
Get the cams
Get a Fuel pump
Get a Tune
Do them all together, you dont want to be driving around with a car that is not tuned for its modifications.
Old Jul 26, 2008 | 08:47 AM
mscorei's Avatar
will the fuel pump change the gas mileage?
Old Jul 27, 2008 | 03:15 AM
mscorei's Avatar
anyone?
Old Jul 27, 2008 | 08:51 AM
Mellon Racing's Avatar
I've been running used HKS 280 cams to 8500rpm for a long time...just inspect them and make sure they aren't scarred up before you buy them.
go ahead and do the fuel pump at the same time and get it retuned for both in one shot and the gas mileage will be fine.
Old Jul 28, 2008 | 02:47 AM
mscorei's Avatar
10x for advice, you're always helpful!
Old Dec 31, 2008 | 07:39 PM
Jp7's Avatar
Jp7
When i changed my fuel pump my mileage stayed exactly the same. You couldn't even tell it was in there with the exception it was a little louder a fuel pump then stock.
Old Jan 3, 2009 | 01:42 PM
EvoDom's Avatar
the IX fuel pump is bigger than the Viii pump. it flows really well. if your doing cams i would just throw the pump in, you might be ok on the stock IX pump but adding cams is going to require more air, and more fuel, get the pump.
