innacurate wideband readings in evoscan 2.4
I have an innovate lc1 wide band installed. it has worked fine in the past but all of the sudden gives me inacurate readings in evoscan. I had to recalibrate the gauge recently as per the 3 month recalibration procedure in the instruction manual. the gauge reads how it should, but evoscan 2.4 is giving me a reading of 4.8 at idle. I cant figure it out. Has anyone else had this happen or know how to fix it?
thanks
P.S. I reinstalled evoscan and restarted twice.
thanks
it seems that there are certain things that can cause the wideband to output jibberish to the gauge and to the computer. recalibrating with the lc1 software seems to be the fix. hope this helps anyone who ever searches. cheers
veszett
Feb 25, 2010 03:20 AM
