500+whp on stock 2 liters??
Old Dec 18, 2008 | 10:42 AM
Mivec2.0's Avatar
hey guys, i wanted to know if i can get 500+whp on a Evo 9 on the stocl 2 liters, im lookin to reach my goal of 600whp, i currently have a HKS Carbon-Ti, HKS Intake, HKS ssqv BOV, and a Greddy profec b boost controller, im goin for a tune soon so idk know my numbers currently, but yea, any suggestions would help, i dont have the money for a stroker kit yet but i was just curious anyway
Old Dec 18, 2008 | 10:50 AM
Import Junky's Avatar
well first off I don't know why you have the HKS ssqv bov. it's a VTA and will cause nothing but problems with your idle and richen you up. As for 500whp, you have a ways to go so I'm not sure why you're asking about it now but it can definately be done on a stock block IX. You can go for something like an HTA 35R and get 500+whp on pump gas with decent spool and decent torque or go with an FP Red with some pump and meth and have great spool and loads of torque. There are plenty of setups out there but I just named two of my favorite.
Old Dec 18, 2008 | 04:16 PM
Mivec2.0's Avatar
alrighty, thanks for the help, im still kinda new the Evo seen and so im trying to research and learn as much as i can, when i bought the car it came with the BOV and the intake, i just bought the boost controller and exhaust , but thanks alot, do you know which BOV's i can use
Old Dec 18, 2008 | 04:19 PM
AWD Motorsports's Avatar
WE have done several evo IX's over 500 on stock motor.. sure you can make 600whp but dont expect it to last long.. if you dont have money for the built motor youll need even more $$$$ when you blow up the stock motor.. just keep that in mind..
Mike
Old Dec 19, 2008 | 06:14 AM
awdboosted's Avatar
It's very easy to do with some money.. But like Mike said, you will run into longevity issues.
Old Dec 19, 2008 | 06:59 AM
Mr. Evo IX's Avatar
You could keep it a 2 liter and put in pistons / rods and still reach your goals. Like others have mentioned, If you go over 500whp it will just be a matter of when and where, not IF your going to experience failure.
Old Dec 19, 2008 | 09:58 AM
Mivec2.0's Avatar
iight thanks alot for the tips, do you guys know of any good pistons/rods i can go with, i was thinkin bout Wiseco, or Oliver or Eagle, and what about the crank, would i have to swap that out also
Old Dec 19, 2008 | 10:03 AM
TheDream's Avatar
Get a Buschur built 2.0L
Ph3n1x's Avatar
Drop in Manleys, and JE Pistons and your down. For the most part at least.
But judging from your mods I would be working to get out of the 300WHP range before thinking bout 500whp or 600whp
Old Dec 19, 2008 | 10:06 AM
Mulholland0132's Avatar
I disagree with this.
I drove my car just over 500whp with my current set up (before my engine build) with no problems for a while. Than when I had the engine built my stock rods and pistons looked perfect. I just built for safety and wanting to run more boost without worry.
I really believe it depends on how you drive the car but mostly your tune. If your not running huge boost and your tune is conservative I think many vendors on here have proven it can be done.
But............Mike@AwdMotorsports is correct....once your pushing 600whp and beyond I can't imagine stock rods and pistons will last very long.
Old Dec 19, 2008 | 10:13 AM
JohnBradley's Avatar
For the meantime, and hopefully to limit the amount of failure you experience, do rod bolts. You wont end up having to look for a block because of boost/rpm induced failure. It does stuff like this:
Old Dec 19, 2008 | 10:15 AM
cpoku's Avatar
Daily Driver or weekend toy?
Old Jan 3, 2009 | 01:51 PM
EvoDom's Avatar
word to the wise, whenever you go big hp, always have money aside for a new motor
Old Jan 7, 2009 | 08:11 PM
john.schuber's Avatar
I wouldn't go over 450whp on a stock block. Yes, people have 600whp+ evo's on the stock block but, 9/10 they will not last. At least get head studs and rod bolts as a minimum.
YoLa
For Sale - Cars For Sale
11
Oct 22, 2015 06:48 PM
nikg
12
Jul 14, 2010 01:30 AM
mrClean5
14
Mar 17, 2010 06:42 AM
David Buschur
159
Apr 16, 2008 08:06 AM
jed
25
Oct 26, 2003 09:45 PM
