Sputter Sputter (video incl.)
Old Mar 10, 2009 | 01:37 PM
[GBU]Moon's Avatar
I recently had a huge exhaust leak in my downpipe, and when my car would get over 10 lbs of boost, it would fart and sputter. I had the leak fixed and my car made it up to 15 lbs of boost before the farting and sputtering.
video:
http://www.fire-pixel.com/temp/sputter.mov
One thing that has happened that may be to blame is my Idle Air Control Valve stopped working properly so my car wouldn't idle. Once the temp was up it would idle extremely low (400-500rpm) and usually conk-out. to mask the problem until my new ICV shows up, i turned the screw on the throttle body out ~3 turns. now the idle is good when the car is warm and i'm waiting on my new ICV before i turn it back.
my question is, is changing the screw setting probably related to the sputtering and farting over 15 lbs of boost? my air/fuel ratio is right at around 15.2 while idling. i'll know once my new ICV is installed, but for right now i'm just looking for piece of mind.
Thanks!
Old Mar 13, 2009 | 10:15 AM
[GBU]Moon's Avatar
installing new IAC Valve this weekend, i'll post the result
Old Mar 16, 2009 | 09:19 AM
[GBU]Moon's Avatar
still sputtering, boost leak?
Old Mar 16, 2009 | 09:21 AM
DaWorstPlaya's Avatar
Did you mess with your TPS sensor? Eg: take it out of the throttle body?
idriveanevo's Avatar
try changing your plugs? had the same issue and it was sparkplugs
Old Mar 16, 2009 | 09:43 AM
[GBU]Moon's Avatar
yes, had a misfire in cyl 1 and that was taken out during the trouble shooting.
Old Mar 16, 2009 | 03:01 PM
Did you mark the TPS sensor when you took it out and put it back together the same way? The TPS sensor is calibrated to the throttlebody and changes values when it is moved left or right during mounting. If it isn't put back the same way, it will misread and give incorrect values to the ECU.
Old Mar 16, 2009 | 11:37 PM
[GBU]Moon's Avatar
my mistake, after looking more closely at what a "TPS Sensor" is, we didn't take that off.
Old Mar 17, 2009 | 08:36 AM
Then it might be your spark plugs, try changing those (as idriveanevo suggested). Make sure you have them gapped correctly.
Old Mar 17, 2009 | 10:22 AM
[GBU]Moon's Avatar
will do, i'll post my results, thanks.
Old Mar 24, 2009 | 06:46 PM
[GBU]Moon's Avatar
bad plug was the issue! I was using some Autolite XPs from Advanced Auto for one month. i installed them while i was troubleshooting a different issue, but now i threw some $2.00 NGKs in there and all is good! thanks for your posts!
Old Mar 24, 2009 | 07:08 PM
No prob, glad it helped
CarrelliEvo8
Dec 2, 2016 09:02 AM
supzack
Oct 17, 2015 11:46 AM
arnoldp
Jan 30, 2013 07:21 PM
imation
11
Nov 2, 2011 02:04 PM
edovio
26
Dec 18, 2007 09:20 AM
