CEL P0141, P0136 replaced rear O2 and cleared. and than...
Old Apr 6, 2009 | 11:19 AM
boostdtalon's Avatar
ok car threw a CEL after replacing the seized turbo. thought it was a boost leak. scanned it and came up with P0141, P0136. after clearing it and trying a few things to see if it would help. nothing still came back with the CEL. so i replaced the O2 and cleared the CEL using my friends scan tool. two cycles of the ignition and it came back. i'm lost as to what i should do next. short of using ecuflash to disable the CEL(yes i've used the search feature). is there anything else i can do. if not looks like i'll be going to pick up a resistor and find someone with ecuflash.
Old Apr 6, 2009 | 09:13 PM
Can anyone help?
Old Apr 8, 2009 | 07:23 AM
seriously no one can give me a possible answer?
Old Apr 8, 2009 | 07:25 AM
mikeevo21's Avatar
r u using a recirc bov?
Old Apr 8, 2009 | 07:26 AM
yes always recirc'd. also forgot to mention i do have a mechanical O2 fix. worked until the turbo swap.
Old Apr 8, 2009 | 07:32 AM
mikeevo21's Avatar
did u try reseting ur ECU?
Old Apr 8, 2009 | 08:03 AM
yep i've reset the ECU and used my friends code reader to clear them. everytime it comes back after 2 cycles of the ignition.
Old May 2, 2009 | 04:06 PM
dscevo8's Avatar
LOL i have the same two cells after swapping the stock turbo to the green...bump for an answer
kambodianboi
May 10, 2013 08:34 AM
LV///R
Jan 6, 2011 02:48 PM
evane
16
Oct 26, 2009 01:59 PM
fq340
Feb 16, 2009 07:33 AM
