Running rich problem
Old Jun 22, 2009 | 09:54 AM
LanEvo06's Avatar
Ok, I recently got tuned. The car runs great from the initial gear. If I punch it in second the A/F's are 11:0 -11:3. But if I shift into third it starts to run rich. 10:0-10:5. If I punch it from third its fine. but when I shift into fourth it goes back to running rich. 1-2, 4-5 does the same thing. Also my idle A/F's are really lean. 17:X - (- - -). Mod list is in Sig. Thanks for any help.
- Vivian
Old Jun 27, 2009 | 05:50 AM
mt057's Avatar
search lean spool and injector latences
Old Jul 15, 2009 | 08:31 AM
sevy2213's Avatar
im having the same problem....have you found anything out about this yet?
Old Jul 31, 2009 | 08:41 AM
Raheelq's Avatar
i'm also interested in finding out what you came up with !
Old Aug 6, 2009 | 07:00 PM
vigilante.zen's Avatar
I would suggest a new tune... That doesnt sound like a typical outcome of a tune... I would get your tuner to take a once over the maps again... If he doesnt see anything time for a new tuner
Old Aug 7, 2009 | 07:08 AM
sevy2213's Avatar
yea thats what i was thinkin....new tune to see if it gets better if not time to go to someone else
Old Aug 9, 2009 | 05:07 PM
Prodigy's Avatar
Was your car tune for more then one boost level.
Old Aug 9, 2009 | 07:13 PM
ROOKHOE's Avatar
The car definately needs a tune, but id check to see if you leanspool is enabled or disabled.
Old Aug 10, 2009 | 11:09 AM
sevy2213's Avatar
the guy turned the boost up to 22 and tuned it there. also i would have no idea if the leanspool is enabled or not even though im not totally sure what it all means. i am tryin to get an apt back there to get this figured out. if not i will buy some more parts and go have it tuned somewhere else again and hopefully have better afr
Old Sep 21, 2009 | 02:26 PM
nonschlont's Avatar
this sounds like leanspool is enabled... Leanspool cause richer afr's after each shift. To eliminate this, you need to disable leanspool, and retune your fuel map.
Old Oct 2, 2009 | 01:23 PM
Go_Lancer_Go's Avatar
where do u locate this?
crf inc.
Lancer Aftermarket Forced Induction Tech
Sep 12, 2013 07:07 PM
TheBigD
Oct 5, 2012 08:07 PM
LANCEREvo9MR
E85 / Ethanol
11
Sep 30, 2009 07:35 PM
ICE888
Jun 2, 2005 06:06 PM
diyath
Jun 18, 2003 07:10 AM
