Evo Scan2.6-JDM MAp, LC-1???
So I just bought Evo scan 2.6 i think...Its the newest version. I switched from mitsulogger because it doesn't support the Innovate Lc-1 wideband anymore..
When i first installed my JDM Map I had to modify some xml definitions for mitsulogger to read it properly. I noticed in Evo scan there is a box that i can check for the jdm map...do i need to do anything else to get an accurate reading? Local atmospheric pressure or anything?
Also I dont seem to be able to get my wide band working properly with it. Its showing readings of 0-4 for afr. wich is obviously wrong.
I dont see any actuall instructions anywhere for the program and the help button just brings you to a support page that I have submitted a ticket to but have not heard a response yet.
Im sure many other people are using this program with the same set up.. what are you guys doing to make it work?
Thakns for any help guys
-Ethan
-Ethan
Thanks for your reply!
-Ethan
evo4mad
May 5, 2015 06:22 PM
