lc-1 install
Old Jan 9, 2010 | 12:14 PM
capman86's Avatar
lc-1 install
I bought an lc-1 with an o-meter a while back from moates.net for my my turbo prelude. I never got a chance to install it and now i recently picked up an evo 8. When i was cleaning the carpet I found a few wires and a wideband sensor ran up through the floor so I was wanting to go ahead and install the lc-1. Apparently the previous owner had one installed and he took it out for some reason? After doing a bit of research on this site I have decided to go with evoscan. I was wondering how I should go about logging, tuning.
I have an ams 2.3 stroker kit, fp red, bov, and some upgraded piping as well as hks cams. I have future plans of e-85 and before i step up i want to get a pretty good understanding of tuning with out spending a lot of money. From my research I would think I already enough equipment so far i have an:
LC-1, O-METER, laptop Tactrix cable.
My main question is what is the best way to intsall the lc-1:
I have a six wires lc-1
red (12v) -hooked up the lighter
blue (heater) white (system)- tied together to the ecu ground
yellow & brown- (do nothing with)
black- with push button calibation and led this is were i get confused!?
Do i tie led and one side of the push button in with the grounds and the other side of the led and push button with the (black) calibration wire?
Do the led and push buttons have to be on separate grounds can i tie everything together with the blue and white?
Thanks!
Old Jan 10, 2010 | 06:04 AM
turbolarry's Avatar
Page 5;
"The grounds to both the cathode side of the LED and the Push button should be connected with the Heater ground (blue wire)."
http://www.innovatemotorsports.com/s...C-1_Manual.pdf
Old Jan 10, 2010 | 06:06 AM
capman86's Avatar
5. The BLUE and WHITE wires should all be grounded to the same ground source.
Optimally, these (and any other MTS device ground) will be soldered to the same lug, and
connected to a single point. When this isn’t possible, connect each one to a separate lug,
and attach in close proximity. Multiple lugs on the same bolt is not optimal, and can result in
unwanted signal “noise.” When possible, soldering is always better than crimping. Please
see chapter 2.3 for more information on Electrical Grounding Concerns
Old Jan 10, 2010 | 03:45 PM
capman86's Avatar
anyone install there own lc-1?
MagicManRed
Oct 25, 2011 10:57 PM
PAdutch
Jul 16, 2010 07:43 AM
EvOSean06
Apr 4, 2010 07:10 PM
KazzEvo8
Aug 6, 2008 02:24 PM
Slick-IX
16
Apr 9, 2008 08:42 PM
