engine problem you experts probably know how to fix
Old Apr 18, 2010 | 07:49 PM
theta chi's Avatar
disclaimer: I tried searching and didn't find a thread with same exact sympoms as i've seen. i didn't have 4 hours to scour the threads so i'm asking for help.
problem: when my engine (stock VIII except for IX blow off valve) is idling, it has a slight fluctuation that started a few days ago for no particular reason. when I drive, it seems to run fine. when I'm stopped at a red light I can hear the murmur again. it is consistent, not wild and usually idles at 900ish
any help is greatly appreciated. please only reply if you feel you have the experience to know a solution
Old Apr 19, 2010 | 04:22 PM
30lbsboosted's Avatar
does it happen after driving at constant speeds like highway driving,or does it happen once you start the car and all thr time
Old Apr 19, 2010 | 05:18 PM
cfdfireman1's Avatar
you have no mods no exhaust no nothing other than the bypass valve? how many miles on the car?
Old Apr 19, 2010 | 07:50 PM
theta chi's Avatar
almost 70k miles, no mods but the IX valve, and it happens after i start engine, at red lights, when i park at home, anytime its idling
Old Apr 20, 2010 | 01:33 PM
Do a boost leak.
Old Apr 24, 2010 | 09:22 AM
theta chi's Avatar
havnt had the chance to check on this for a few days. could you explain what it means to do a boost leak
Old Apr 24, 2010 | 09:32 AM
mifesto's Avatar
considering you have 70k and you havent modded, im gonna take an educated guess and say check your EGR for loose vacuum hose
Old Apr 24, 2010 | 09:40 AM
buchnerj's Avatar
I second. If no modding has done is has to be a vacuum line somewhere in the emissions setup under the hood, behind the intake manifold, or it is a boost leak at a coupler somewhere.
Ted B did this a while back. You don't have to use welded nice parts as he did, many people use PVC and it works just the same.
Old Apr 25, 2010 | 05:44 AM
sorry "boost leak test" https://www.evolutionm.net/forums/ev...g-how-why.html
Old Apr 25, 2010 | 05:59 AM
evo_q8's Avatar
Click here for a boostleak tester - PPI
I use this and they are really good.
best of luck!
Old Apr 25, 2010 | 08:15 PM
theta chi's Avatar
wow so much information. thanks evo g8, cfdfireman1, buchnerj and mifesto
ill letu guys know what turns out
Old Apr 28, 2010 | 04:56 PM
EVO8STI's Avatar
yup im betting that the green striped vacuum line came off the egr
Old Jun 3, 2010 | 06:54 PM
theta chi's Avatar
so I finally got her to the shop, turned out to be running rich due to a bad O2 sensor. expensive
Old Jun 4, 2010 | 12:22 AM
EVO8STI's Avatar
oh that sucks.. like 400ish right
Old Jun 4, 2010 | 12:24 AM
EVO8STI's Avatar
do you not have a a/f ratio gauge, if not id invest... you would have known the reason for your problem a long time ago
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Vehicle336
Aug 31, 2017 06:22 PM
Boombox
32
Jan 23, 2016 02:34 AM
DanJ
Sep 6, 2013 03:01 PM
Hen5000
Dec 15, 2008 05:43 PM
