interfacing a wideband O2 sensor
Old Dec 7, 2003 | 09:49 PM
SlowCar's Avatar
Does anyone know if it is possible to interface a wideband O2 sensor to something like a safc, so that a real time AF ratio correction can be done to a preset level?
Old Dec 10, 2003 | 06:23 AM
gunzo's Avatar
Re: interfacing a wideband O2 sensor
Yes .. only if you're not running the greddy pressure sensor.
You hook up the voltage out from the wideband O2 to the MAP sensor port, and it basically reads the voltage from 1-5v..
Software glitch prevents you from logging though.. but you can see it real time when you select greddy pressure sensor on the injector control map
Old Dec 11, 2003 | 11:03 PM
Alchemist's Avatar
Was the glitch fixed in the 1.36 release or no?
Old Dec 12, 2003 | 05:07 AM
gunzo's Avatar
Nope .. I'm running the 1.36 and I still can't run ignition on my car
Old Dec 14, 2003 | 11:08 AM
3deep's Avatar
Is ignition still a problem with emanage,should you only run injector harness.
Old Dec 15, 2003 | 04:30 AM
gunzo's Avatar
Yes .. they came out with an adaptor harness to fix the frying .. but it didn't work for me .. apparently .. the adaptor harness works for certain cars .. and doesn't work for others .. and all of them evos
I just run the fuel control only .. just couldn't figure out why the ignition doesn't work .. the japanese are facing the same problem ..
Old Dec 15, 2003 | 01:14 PM
992gnt's Avatar
You drive a GT-A, are all of them automatic transmission cars? Wondering if there is a connection as to why some work (like mine) and some don't (like yours).
Old Dec 16, 2003 | 09:43 PM
gunzo's Avatar
Nope .. no connections .. those that don't work are mostly VII/VIII GSRs .. haven't heard any ignition that work fine on the JDM cars yet .. only USDM cars seem to work .. except it fries when the car is not started .. maybe the USDM cars runs differently ??
Old Jun 1, 2004 | 08:02 AM
Po Dunk's Avatar
From the IS300 forums.
we've been having problems with the ignition harness on 02+ IS300's
It seems that jumper one switches the ignition configuration from pull up to pull down.
jumper 2 switches the ignition configuration from 12V to 5V.
Try switching jumper one around if the ignition harness is completely dead and you're sure the coils are correctly wired.
Casey Robertson
Mar 21, 2016 08:25 PM
Jonas
Lancer Engine Management / Tuning Forums
12
Apr 15, 2009 04:17 PM
GiGas
Mar 29, 2009 02:42 PM
fxyxixe
Oct 22, 2008 07:54 AM
nplatenkamp
Feb 15, 2008 07:31 AM
