Passing emissions testing with a JDM Evo 7??
Old Mar 7, 2011 | 12:03 PM
Grip Master's Avatar
Hey guys, i'm looking into buying a jdm evo 7 that a friend of a friend owns. he lives in a county that doesn't have to do emissions testing, however, I do. I am trying to figure out a way that the car can pass the tests. I believe that JDM cars don't have o2 sensors so I don't know if it's somehow possible to make the ecu say that the car has passed the tests. I've seen the "patch" threads, however to make that work i'm sure the patch has to be modified, or maybe there is some other way to do it. I've contacted several local tuners and am waiting for replies. Thanks In advance for any help guys!
-Zack
Old Mar 9, 2011 | 10:30 PM
tscompusa2's Avatar
you have to paste the code into the XML file located in rommetadata\mitsubishi\evo. once the xml is updated that is linked with that rom id, the tables will appear & then you can use the emission hack stuff.
Old Mar 10, 2011 | 01:20 AM
grayw's Avatar
As I posted in the other thread, JDM cars don't have rear O2 sensors, as there is no pre-CAT in the downpipe. They do all however have an O2 sensor in the turbo elbow to control closed loop fuelling.
You will probably have to swap rom ID's as I doubt any of the rear O2 sensor code will be present in the JDM rom.
richardjh
May 24, 2026 12:49 AM
richardjh
Nov 6, 2024 04:41 AM
CJK
34
Apr 1, 2017 05:24 PM
supak111
Mar 16, 2016 12:17 AM
sdfontanini
E85 / Ethanol
Apr 1, 2009 09:07 PM
