How do I go blow through (MAP only)?
Old Sep 1, 2011 | 11:32 AM
CtSilver03Evo's Avatar
Hey guys,
Sorry if this is a really noob question. I'm putting a fully-built Buschur motor in my car right now, and this winter plan to put an HTA35R or FP Black in the car. I already got an Omni 4-bar MAP sensor....
What else do I need tune from MAP and eliminate my MAF? Just a tune? Or other parts?
Thanks!
Old Sep 1, 2011 | 11:39 AM
binky's Avatar
Originally Posted by CtSilver03Evo
Hey guys,
Thanks!
You also need an IAT and a bung installed in your UICP in order to install the new sensor.
http://www.maperformance.com/aem-inl...ensor-iat.html
You then need to wire that sensor into your old MAF connection. You could use this pre-made wire from http://www.spoolinup.com/:
-Bink
Old Sep 1, 2011 | 11:44 AM
Ev0ikon's Avatar
You would need an air temp sensor. Or you could go cheaper route and take the temp from the fuel supply.
And about $500 for a good custom tune. :}
Last edited by Ev0ikon; Sep 1, 2011 at 11:56 AM. Reason: oops. he beat me to it. or Am I just slow? :p
Old Sep 1, 2011 | 11:45 AM
05blue8's Avatar
If you're referring to going Speed Density then you'll need your intercooler pipe modified with a bungsfor the appropriate sensor. There are easy ways and harder ways to do it. There's a harness you can buy available now so it's all plug and play, no splicing etc necessary. The only real modification is welding in a bung. These guys also make a harness - http://www.spoolinup.com/ that has gotten great reviews. That and the new intake pipe and a sensor is all you need.
Rpf1evolution
Jul 23, 2017 06:56 PM
thepoint4life23
Jun 15, 2016 04:04 PM
NitroWD
Jun 11, 2016 11:01 PM
egis
Jan 6, 2016 07:55 PM
rstchris
May 22, 2011 02:30 AM
