proefi!
Old Feb 16, 2012 | 07:39 AM
n2oiroc's Avatar
proefi!
It has arrived! Thing is huge, glad the harness is 5' long as its going to have to go under the passenger seat.
As soon as its installed and running in a couple weeks ill update with more info.
Old Feb 16, 2012 | 08:39 AM
SDevo13's Avatar
Subscribed
Old Jul 2, 2012 | 12:24 AM
MasterNater's Avatar
Any updates? I'd like to know what you think of this system.
Old Oct 3, 2012 | 10:18 AM
n2oiroc's Avatar
having a bit of trouble. the ecu was missing a file so i was emailed a dll file to download. still cannot change the maps on it. anyone have any ideas?
when im connected to the ecu, all this is blank. offline, its all filled in with the info.
occasionally get this even though i downloaded it in various locations.
shows it as uploading a map, but it never actually makes it to the ecu.
when i try and create an ecu file, i get this.
Old Oct 3, 2012 | 10:50 AM
Liqquid's Avatar
so you have a .srz? the .xcal are just the calibrations (that's what will be in the folder shown, but it's looking for .srz, which is the "base" file that programs things you won't want to change on the fly, such as number of cylinders, firing order, etc) the .srz are kept in a folder called "programs" by default. you need one to do the "create ecu file". Otherwise you can download .xcal from the ECU, to open it and modify it you would select a .srz on your computer..
Old Oct 3, 2012 | 11:16 AM
n2oiroc's Avatar
i cant find any .srz anywhere on my pc. whenever i try and save the file off the ecu it only gives me the .xcal option and there is no info in the serial # area or anything.
Old Oct 3, 2012 | 11:33 AM
Liqquid's Avatar
hmm, used to come with some when you downloaded the user software..
http://proefi.com/info/software-downloads/
I'd give them a call if not, can probably verify a few things too and make sure the ECU is on the right firmware, etc... not sure why it's not connecting (that's what it looks like anyways)
Old Oct 5, 2012 | 08:34 AM
n2oiroc's Avatar
thanks for the help. im waiting for a complete base map and all the files to be emailed to me. ill update with the results.
Old Feb 27, 2013 | 12:48 AM
SpinALL4s's Avatar
how much would this unit cost me to run on my evo9?
Old May 12, 2013 | 06:23 PM
n2oiroc's Avatar
more info that may help some out. here are the pins for adding wires to the harness. most vendors want $1 each and $10+ shipping for them. this place and a few others stock them for $0.24 eack and cheaper shipping. they are verified with calipers and against the prints and other pins i had to be 100% correct.
http://www.mouser.com/Search/Product...cjbqE8aw%3d%3d
n2oiroc
Aug 27, 2016 03:12 PM
n2oiroc
Jul 17, 2016 11:29 PM
n2oiroc
May 1, 2016 03:08 PM
n2oiroc
Apr 4, 2012 07:07 PM
n2oiroc
31
Nov 29, 2010 08:49 AM
