Evo 8 ecu in a 2G, ecuflash unable to connect to vehicle interface
Old Jan 12, 2013 | 10:37 AM
04evony's Avatar
So i have a 97 gst. I recently converted it to Evo 8 ecu. so the car turns over but wont idle. prob due to the ecu being tuned for 2000cc injector and i only have 750cc injectors. i bought a tactrix cable and downloaded ecuflash. when i try and read the ecu this is what comes up.
[13:35:26.974] EcuFlash Version 1.44.3721
[13:35:26.974] OS Version Windows 7
[13:35:26.974] Qt Version 4.8.0
[13:35:27.004] 63 memory models read.
[13:35:27.004] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[13:35:27.444] 611 ROM metadata models scanned.
[13:35:27.444] checksum module "subarudbw" loaded.
[13:35:27.444] checksum module "mitsucan" loaded.
[13:35:27.444] checksum module "mitsuh8" loaded.
[13:35:27.444] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[13:35:27.444] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[13:35:27.454] flashing tool "wrx02" loaded.
[13:35:27.454] flashing tool "wrx04" loaded.
[13:35:27.464] flashing tool "sti04" loaded.
[13:35:27.494] flashing tool "sti05" loaded.
[13:35:27.494] flashing tool "mitsukernel" loaded.
[13:35:27.494] flashing tool "mitsukernelocp" loaded.
[13:35:27.494] flashing tool "mitsubootloader" loaded.
[13:35:27.494] flashing tool "shbootmode" loaded.
[13:35:27.494] flashing tool "shaudmode" loaded.
[13:35:27.504] flashing tool "subarucan" loaded.
[13:35:27.504] flashing tool "subarucand" loaded.
[13:35:27.514] flashing tool "mitsucan" loaded.
[13:35:27.644] Using interface OpenPort 1.3 Universal TX26VysAd28bf6d5c65d352d57e7bc12f04b99bf8d12a8aa
[13:35:27.644] interface close
[13:35:27.734] Using interface OpenPort 1.3 Universal TX26VysAd28bf6d5c65d352d57e7bc12f04b99bf8d12a8aa
[13:35:27.734] interface close
[13:35:27.834] Using interface OpenPort 1.3 Universal TX26VysAd28bf6d5c65d352d57e7bc12f04b99bf8d12a8aa
[13:35:27.834] interface close
[13:35:39.804] using metadata XML ID read_evo7 from file C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata/read templates/read_evo7.xml
[13:35:39.934] Using interface OpenPort 1.3 Universal TX26VysAd28bf6d5c65d352d57e7bc12f04b99bf8d12a8aa
[13:35:39.934] interface close
[13:35:39.934] unable to connect to vehicle interface.
Does anyone have any idea of what i should do. this is my first time trying to tune. figure if im going to learn let it be on my own car. my flash pin is correct and all the wiring is done right. oh and battery voltage is good.
Old Jan 12, 2013 | 12:23 PM
AWDBus's Avatar
Check to make sure you have the right vech. checked for logging. Sometimes I click other cars in the top option and it will not connect.
Old Jan 12, 2013 | 03:17 PM
04evony's Avatar
ya im clicking on the right vehicle. i also tried the other vehicle options and nothing works
Old Jan 12, 2013 | 05:40 PM
Ev0ikon's Avatar
Old Jan 24, 2015 | 06:56 PM
canclled's Avatar
this issue ever solved? I'm having the same problem.
Old Feb 5, 2015 | 09:15 AM
canclled's Avatar
are you using the 1.3cable or the 2.0? I had the same problem with 1.3 cable with the new version of ecuflash so I downloaded the 1.29 ecuflash and it work. For my 2.0 tactrix, the cable is broken and not connecting. try it out.
Old Feb 6, 2015 | 11:20 AM
MikeyPSF's Avatar
Hey canclled, can you send me an email to support at tactrix dot com? I'll help you sort out whatever issue you're having with the 2.0.
In general I would avoid using a version of EcuFlash that old. That revision would be at least 5 years old if not older. You're missing a lot of driver and firmware improvements. Send us an email and we'll help you sort out the issue.
-Mike
Old Feb 7, 2015 | 02:11 PM
canclled's Avatar
Issues
I have 1.3u cable and I cant connect it to the new version and I was searching here that they had success with 1.29, so I used that to study the tuning. But I also have the 2.0 Tactrix and that's what I've been using with the new version. The only reason my 2.0 Tactrix wasn't working because the cable is broken. If you can help me figure out how to work the 1.3u cable that would be awesome
Old Feb 7, 2015 | 02:30 PM
MikeyPSF's Avatar
Sure, send me an email to support at tactrix dot com and we'll do some troubleshooting. I can also send you a USB cable for the 2.0 if you need one, but they're just a common mini USB cable like the one you'd use for a digital camera, GPS, hard drive, etc..
Hollywood_Evo
Nov 8, 2011 06:22 AM
monkeyevo
Aug 2, 2011 01:52 PM
shawn_090
Mar 23, 2011 01:38 PM
4mypsp
Apr 30, 2010 12:27 PM
