Can someone explain the difference in Tactrix Products?
Old Jun 29, 2013 | 06:09 AM
whotippedmycow's Avatar
Hello Tuners,
I recently purchased an Evo 8 and I am looking into getting it tuned or learning it myself. I see there are items like:
Tactrix Openport 2.0 http://www.tactrix.com/index.php?pag...mart&Itemid=53
EvoScan cable http://www.evoscan.com/evoscan-gps-o...flashing-cable
And recently I saw a Tactrix 1.3 cable but I can't find it anymore.
What cable do I need?
Old Jun 29, 2013 | 06:17 AM
I assume the Tactrix 1.3 is the same as Openport 2.0 just a older version.
Old Jun 29, 2013 | 06:40 AM
Wheelie's Avatar
I believe the Openport 2.0 is for newer cars like the EvoX. You can buy the reflash adapter to use it on older Evos 5-9. I think you will need a Tactrix 1.3u with evoscan software (the 2nd link you have in your post).
Old Jun 29, 2013 | 06:51 AM
Appreciate it! Think I finally figured it out myself but wanted some more info Looks like you can get an adapter for the 2.0.
Old Nov 29, 2013 | 07:58 AM
Shinzon's Avatar
wait, i thought u can use the tactrix 2.0 on all evos. its just that pre evo x needs an adapter for reflash only. i know there was problems with using it with evoscan 2.6 but it seems that has been fixed. correct me if i am wrong
Old Dec 1, 2013 | 07:40 AM
Wheelie's Avatar
You are correct. But if you have a Evo 7/8/9 the 1.3u is the favorable cable.
Old Dec 1, 2013 | 07:58 AM
Terror Rising's Avatar
^ What he said. It datalogs faster and is cheaper.
Old Dec 1, 2013 | 03:01 PM
Broke4speed's Avatar
The Evoscan 1.3 was originally made by Tactrix, then the design was given to Evoscan once Tactrix came out with the 2.0.
Old Dec 3, 2013 | 02:29 PM
Shinzon's Avatar
just ordered a 1.3u , was using my neighbor's. i almost bought the 1.3r but it seems 1.3u is over all the best cable for sub x evos
Old Dec 4, 2013 | 05:58 AM
The U just allows for use with the latest ECUFLash to read/write. If you have an Evo 8/9, the R works fine with EVOScan for flashing.
Old Dec 5, 2013 | 02:43 PM
Shinzon's Avatar
how do u edit the tables? using evoscan?
Old Dec 6, 2013 | 02:09 PM
Toekneee!'s Avatar
In evoscan if you open the maptracer you can view live values. In the second graph from the top you'll see a timing map. Right click and load your ROM. After that log some pulls. You can directly edit the tables in the map tracer by pressing [ or ]. You can right click and save after then flash.
In response to OP, 1.3 cable seems to work best for anything before the X. Still can't read DTC with my 2.0 cable but everything else works fine.
jay777
Mar 25, 2016 01:44 PM
Casey Robertson
Mar 21, 2016 08:25 PM
thejoshster
Mitsubishi TC-SST Discussion
78
Aug 13, 2012 12:47 AM
lonestarevo83
Jan 10, 2012 02:54 PM
mmixan
Sep 17, 2011 04:29 PM
