Standalone and wideband
Old Dec 11, 2013 | 03:12 PM
211Ratsbud's Avatar
I've had the aem wideband wired to the stock ecu for some time. I got a vipec and I want to ensure that the vipec doesn t see a varying wideband reading from ground offset just like the stock ecu tends to. Where is the best place to ground the aem so that the grounding is infallible.
Can i tie it into a sensor ground pin to the ecu ? I will be pinning it to the factory front o2 sensor. And also using it in that location. As I will be using quick tune and wot fuel corrections ..
Old Dec 12, 2013 | 06:55 AM
Broke4speed's Avatar
The battery negative is the best place IMO.
Old Dec 12, 2013 | 12:18 PM
211Ratsbud's Avatar
Is there any equivalent spots in the cabin / loom? Would the sensor ground cause interference with anything ?
Old Dec 12, 2013 | 12:28 PM
Ideally, the best place to wire the wideband is the same place the stock ecu is grounded. A sensor ground would work, but if there's a ground to the chassis from the ecu, I'd use that.
Old Dec 12, 2013 | 01:04 PM
211Ratsbud's Avatar
Gotcha thanks!
martinPL
Jun 14, 2016 04:12 AM
evodziobak
Jan 26, 2016 04:24 AM
martinPL
Jan 26, 2016 04:21 AM
evo8in203
Oct 3, 2013 07:18 PM
tboboy
Aug 7, 2010 03:39 PM
