Need help with my engine questions please. Urgent
Old Sep 16, 2013 | 03:25 PM
Brettpeters's Avatar
Ok I just bought a 03 evolution. Yes I am a newb How do I find out what number of evo is it? Also main thing is I blew my engine. I'm looking at the 2.3rr AMS crate. Will this engine bolt in and to my turbo? Will my transmission work with it? Will I need a tune after? Anyone know where to get a good tune around central Illinois? Also how do I find out what turbo I have?
Old Sep 16, 2013 | 03:48 PM
Pal215's Avatar
You have an Evo 8. How did you blow your engine ?
The AMS 2.3rr is a high end motor that usually only dragsters or track enthusiasts use, although I suppose one could daily drive it...
Yes, Technically your turbo and trans will bolt up to it. You will need a tune.
Take some pictures of the turbo and post it up. People here can tell you just by looking at it.
-pal215
Old Sep 16, 2013 | 03:52 PM
Pal215's Avatar
Start here.
https://www.evolutionm.net/forums/ev...faqs-forum-61/
Read Carefully and take your time.
Good Luck on repairing your car!
-pal215
Old Sep 16, 2013 | 05:38 PM
I have no idea I just got this evo and I was driving home from work at about 65 and it threw a rod I do believe oil was spewing out and the car almost burnt to the ground. Here's my turbo. The trans is the five speed and idea what tranny it is also the turbo?
Old Sep 16, 2013 | 06:29 PM
where is there to get a decent priced engine?
Old Sep 21, 2013 | 08:14 PM
barneyb's Avatar
https://www.evolutionm.net/forums/ev...evo-8-9-a.html
Old Sep 22, 2013 | 04:45 AM
JaYr_EvO9's Avatar
Why dont you just give them a call automotosports (AMS) there in the same state as you. You did say you wanna buy there motor they could probly recommend something else or build the one you have.Also hard to say what turbo and trans with out serial numbers. Ask the person you bought it from. Again contact AMS there in West Illinois they can be some help
Hope this helped
Old Sep 22, 2013 | 05:50 AM
jhoganusaf's Avatar
looks like the stock TD-05 16g turbo. and more than likely the stock 5 speed transmission is in it.
David Buschur
Aug 1, 2017 02:29 PM
2006EvoIXer
58
Jul 9, 2017 09:43 AM
Lodus
Nov 6, 2014 08:00 AM
BensLancer
Lancer Engine Tech
Jul 7, 2007 11:13 PM
J!n K@z@mA
Jan 19, 2006 02:55 PM
