03 EvO 8 ignition troubles Pls Help!
Old Nov 17, 2014 | 11:13 PM
ffsman12's Avatar
Question 03 EvO 8 ignition troubles Pls Help!
So I have been outside trying to figure out what's wrong with my evo 8, changed out spark plugs for some new NGK lazer ones, an when I did put back together the car started sputtering, wasn't sure the problem so put old plugs back in and the car was still sputtering as if it was out of time or vacuum leak I don't know! Kinda new to the evo... Need help guy at auto zone told me to reset ecu and drive it for awhile and should work but that didn't change it.... Car idles rough but when give it gas the car drives/runs fine.. Just when in neutral and idling what could it be?
Old Nov 18, 2014 | 09:49 AM
Ev0ikon's Avatar
Get from NGK BPR8ES and gap them to 0.020".
If you still have issues after than then do a boost leak test. Don't come back until these 2 things are done!
Old Nov 22, 2014 | 03:17 PM
robbyredneck's Avatar
marion in what state?
Old Nov 24, 2014 | 11:37 AM
ffsman12's Avatar
Think it's my magnecor spark wire it is tore up pretty bad gonna try replacing
Old Dec 29, 2014 | 03:18 PM
ffsman12's Avatar
I got NGK BPR8ES plugs gapped at .020 and it smoothed out more but still sputtering shouldn't it be gapped more read about people saying gap at .032?
Old Dec 29, 2014 | 04:21 PM
no, low .020's . did you check for vac leaks? wouldnt hurt to clean your maf.
Old Dec 29, 2014 | 07:01 PM
ffsman12's Avatar
Oh okay. Um well I need to check that and could a boost leak cause a sputtering problem aswell? Cause I normally push 25lbs but it's been goin to 21-22lbs my evo isn't stock if that helps with the gaping it's had cam work done titanium parts and has around 375-400hp
Old Jan 1, 2015 | 05:37 AM
3gturbo's Avatar
They already told you how to fix it. Most likely you either messed up one of the plug wires or you disconnected a vac hose. This is a simple repair and if you wont listen to the people trying to help you then take it to a shop that knows what their doing. Not trying to be a jerk but they told you to do a boost leak test if you dont know what that is you shouldn't be working your car yourself.
Old Jan 11, 2015 | 02:59 PM
ffsman12's Avatar
Okay, got me the BPR8ES plugs gapped at .020 and took to shop got boost and vacuum leak, they fixed a boost leak around turbo and fixed a vacuum line that was bad and helped a lot better but still sputter a bit and when get on it the car hesitates a bit... Any ideas to this?
I appreciate the help everyone!!!!
Old Jan 13, 2015 | 08:33 AM
Ev0ikon's Avatar
Did you really find ALL the leaks? Did you pressurize the entire system (to about your boost target/PSI) and hold it there for at least 5 seconds?
Old Jan 13, 2015 | 07:19 PM
ffsman12's Avatar
Not completely positive, the guys would let me see then do it... Went to Appalachian Performance in Black mountain NC, guys said found 1 boost leak and fixed a rubber house for vacuum... So can't tell if there is a boost leak! Any suggestions on what I should do??
Old Jan 15, 2015 | 08:31 AM
Ev0ikon's Avatar
The only way to know of a leak is to pressurize the system. It's not really that hard.
pinoy_gm808
17
Oct 9, 2010 12:15 AM
dragon831
Oct 3, 2009 06:24 AM
dragon831
Oct 2, 2009 01:08 PM
