high knock on logs
Old Nov 18, 2014 | 07:34 AM
EVOLUTION9MR's Avatar
high knock on logs
So I recently started logging my car I have my wideband hooked up to my ecu. Looking at the logs i only get knock in the 4000 rpm range. Only 1 count. But I did a non wot log and knock is all over the place. I went from 30 to almost 90% throttle an I get 6 and up to 9 counts. So my question is it normal for this to happen like if you let go off the throttle will the ecu pull timing depending on when and how you handle the throttle? Like I said on a straight wot run I only get 1 count and that's fine. But what about when I'm not going wot what can be expected there? Should there be no knoknock at all?
absolut525
Aug 23, 2016 11:35 AM
AWDb00st239
Feb 10, 2015 03:49 PM
thedru13
Nov 3, 2014 08:58 AM
stealthMR
Jun 6, 2011 06:56 PM
Crester
Nov 17, 2010 08:09 AM
