Datalogging Cable, Evocan and tuning
I'm sure this question gets asked a lot, but I've been an Evo owner for 5 days so please excuse my naivety. I am looking to get a obd2 cable to use to data log my Evo 9 and there seems to be several different ones out there. Yes I do know some Subi guys so I suppose I'll want the compatible cable. It seems like there is a general consensus that Evoscan is **** so no questions there. Any help or suggestions for a first time owner would be great, thanks!
any updates on this? I'm a new evo owner myself and just installed a wideband, planning on tuning myself.
I bought the 1.3U cable because Evoscan said it was faster at logging the Evo 9s and I really didn't have a reason to data log when not hooked up to a laptop. Depending on your wideband, you can wire it directly to the ecu by replacing the signal input from the rear O2 with the linear output signal wire from the wideband.
http://www.microcenter.com/search/se...&myStore=false
The Winbook tablet is full Windows 8.1 & comes with a full size USB port.
I am personally using the TW801 with 2GB of ram. Its definitely not a powerhouse of a tablet, but I literally only use it for Evoscan so it doesnt need insane specs & it works well for a single task in my opinion.
What did you mean by pinned 9? I dont think the rear O2 slot was #9 on the ecu diagram, it was in the 60s or 70s if I recall.
I looked, but couldn't find the 801 model. I would be using it for just evoscan and tuning also. Did you mount this to display gauges or just pull it out when logging and tuning?
You dont need to hack a tomtom, this is what ive been using with great results!
You must edit the ROM. You log with EvoScan and tune with ECUFlash.
https://www.evolutionm.net/forums/ec...evo-8-9-a.html
holycrap300
May 18, 2011 09:34 AM
PHDoc19
Aug 5, 2010 04:12 PM
TurbotrixRacing
Apr 6, 2008 05:57 AM
