Hiccup/stutter at peak boost
Old Jun 28, 2016 | 06:53 PM
butte's Avatar
When I go WOT, and hit peak boost of around 28psi around 4800rpm (not on stock turbo), I get random little stutters or hiccups until redline. I can't think of any other way to describe them. They're a very brief loss of power for a like split second. Evoscan logs absolutely no knock. I just replaced the sparkplugs with NGK 1 step colder iridium plugs, thinking that might be the issue, but to no avail. AFRs are fine, timing map is reasonable. It's not fuel cut, I've experience that before and this is not it.
Can't think of what else it could be? Considering replacing the spark plug wires and boots out of desperation.
Looking for opinions
Old Jun 28, 2016 | 08:35 PM
roni4g63's Avatar
Take off your uicp and see if your throttle body is dirty, and obviously make sure you have the corect plug gap. Last but not least do a boost leak test too.
Old Jun 28, 2016 | 09:06 PM
butte's Avatar
Sorry, should have mentioned. Did a boost leak test, fixed a couple of tiny leaks but nothing worth mentioning
Old Jun 28, 2016 | 10:05 PM
edsct9a's Avatar
Which plugs did you get and what did you gap them to? I had the same problem and my gap was to high.
Old Jun 28, 2016 | 11:51 PM
Lazyfong's Avatar
I had a similar problem and it was my coil pack.
Old Jul 2, 2016 | 03:54 AM
400s's Avatar
what gap are you running on your plugs?....
infini_IV
Jun 23, 2009 06:47 AM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
127
Apr 23, 2009 02:16 PM
DynoFlash
15
Aug 23, 2007 04:57 PM
jcsbanks
Jul 19, 2006 12:32 PM
turbotool
Jun 22, 2005 09:26 PM
