I dont see much Evo guys using Accesports. What do you use instead?
Old Aug 28, 2017 | 01:32 PM
Womb Raider's Avatar
Veteran: Marine Corp
Unhappy I dont see much Evo guys using Accesports. What do you use instead?
What do you guys use instead of Cobb Accessport. Ive only ever seen Subi guys with them. I'm looking to get a tune and run two different maps something like everyday driving and then a more aggresive tune. Or even have one running E85 and another running pump gas and would like to be able to switch it as fast as possible whenever need be.
Old Aug 28, 2017 | 02:12 PM
Chrispy0530's Avatar
I use ECUFlash/EVOScan.
Old Aug 28, 2017 | 02:43 PM
e_kobz's Avatar
Open source all the way
Old Aug 28, 2017 | 05:28 PM
So tactrix cord?
Old Aug 28, 2017 | 05:47 PM
mrfred's Avatar
Originally Posted by Womb Raider
So tactrix cord?
Yes.
Old Aug 28, 2017 | 06:22 PM
Anyone have a little bit of time to explain this conpared to an accessport
Old Aug 29, 2017 | 06:33 AM
mrfred's Avatar
Its very much a DIY system. It requires learning how ECUFlash and EvoScan work, and then its up to you to either use the table definitions supplied in ECUFlash, or if those don't provide what you need to tune your Evo, find the needed ones on EvoM. Pretty much everything needed is out there, but its spread all over the place, typically in threads that describe what the table(s) do.
Old Aug 29, 2017 | 07:44 AM
Biggiesacks's Avatar
This should help you get started
https://evoecu.logic.net/mirror/merl...UIDE-V1.7a.pdf
Old Aug 29, 2017 | 09:27 AM
Wheelie's Avatar
Here is a playlist of videos for Introduction to Ecuflash.
https://www.youtube.com/view_play_li...F5C03E946&hd=1
Old Aug 29, 2017 | 07:52 PM
Thanks for the link! Looks like i have some reading to do
Old Sep 15, 2017 | 07:11 PM
D1andonlyantman's Avatar
Not too many months ago I knew virtually nothing about how to tune a car, but I've recently started mapping my ix. Merlins guide and that ecuflash tutorial are very useful, and if you know someone who doesn't mind explaining them little things that just don't quite click at first, then you're away. If you already know a bit about tuning then you should have no trouble at all.
Old Sep 15, 2017 | 08:44 PM
shutterboy10's Avatar
5 Year Member
thx for this info
mitsuevodriver
Apr 8, 2010 04:45 PM
habboub
Nov 14, 2009 12:05 AM
Craig King
17
Aug 16, 2009 07:43 AM
exacc
Feb 26, 2008 03:53 PM
